A/C Compressor won't disengage
Old Jul 18, 2011
Civic96LX's Avatar
Civic96LX is an unknown quantity at this point
Hi all. I'm turning to the forum for help with my 96 LX. A/C quit working last month and mechanic suspected bad ecu. Replaced the ecu with one I found on ebay that had the same numbers. Now the clutch is always engaged, even with the switch turned off. Could this be a bad ecu or perhaps for a non a/c car?
Thanks
Old Jul 20, 2011
98EKCoupe's Avatar
98EKCoupe is an unknown quantity at this point
Re: A/C Compressor won't disengage
does the compressor stay on even when you set the a/c switch to off? If so check the underhood relay could be possibly stuck, also possibly a bad ECU, dealing with used modules is typically a bad idea, you don't know what you're getting
Old Jul 21, 2011
Civic96LX's Avatar
Thanks 98. Compressor is on with switch off and the relay is good. Green A/C button light works. Either bad ecu or I have a short in the compressor wire. Reason I went with used is because the car is to the point that money spent won't be recovered.
Dave88LX
Jun 2, 2016 03:43 PM
alxz310
Jul 30, 2015 12:18 PM
AaronSorenson
Jul 7, 2015 09:40 PM
ZILLA
Jul 5, 2015 05:24 PM
g4384063
May 30, 2015 11:21 AM
