Window repair
Window repair
So when i roll up the driver window it goes up then stops. after that i have to move it down then back about twice to let it reach to the top. how would i go about repairing that. Is it just lubricate the regular or just buy a new one completely.
honda civic 1997 hx
honda civic 1997 hx
Re: Window repair
had the same problem on a 96 hatch. turned out to be just a worn regulator. lots of pivot points on it to wear over the years. got a new one from the dealer for about $70 and except for a small hangup due to needing to replace the window seal it works like new. was also a really quick easy swap.
Re: Window repair
Lube the regulator and if that doesn't work it's #1: http://www.hondapartscheap.com/south...t=0&quantity=0
Re: Window repair
so i lube up the regulator and nothing, but i think i might have reinstalled it incorrectly. the window is much worse now, gets stuck about 2/3 of the way up. had to raise it with my hands. any advice on reinstalling it?
do i buy a new motor as well? or just the regulator?
Re: Window repair
sorry, mine is a dx hatch so it is manual. but a few months ago I replaced the entire assembly on a 2002 ex for a friend. she got a new regulator and motor from carquest for $50. I had it swapped out in less then 1/2 an hour.
Re: Window repair
thanks for the help guys!
i was able to put everything back in working order.
the window moves up and down smoothly now.
it squeaks a little but thats because one of the bolts holding in the wheel in the regulator has worn out and doesnt hold it as steady as the other one.
thanks again for all the help!
dtdoyle
25
Aug 30, 2015 06:57 PM
JLee93
Aug 21, 2015 05:44 PM
Burgeogull
Aug 14, 2015 05:12 PM
brady15
Aug 8, 2015 08:16 PM
Jul 14, 2015 03:39 PM
