Stalling Issues
Old May 3, 2011
Kidney Grills's Avatar
Kidney Grills is an unknown quantity at this point
Stalling Issues
Hey everyone. My 1998 Civic LX recently went through a flood and so far I've changed the oil replaced distributor cap and rotor, crankshaft sensor, wires and spark plugs. I got the car running again after a few days of drying it out. I also took the ECU out and dried it with a hair dryer. The car runs for a bit but then the battery light comes on, all the electronics in the car dim and it eventually stalls. It seems that the car is running just off the battery. Usually this would be an alternator problem, but I suspect it may be the ECU. Does anyone have any ideas? The water was up to the speakers on the doors btw.
Old May 5, 2011
lazlong's Avatar
Re: Stalling Issues
Just because the water didn't get to the alt doesn't mean that it didn't short out. Have the alt tested first then go from there.
Also the harness may be corroded from water damage causing intermittent shorts and whatnot. Check the harness, especially the connectors (most vulnerable spot for corrosion).
jbradley4809
Apr 7, 2017 04:23 AM
The Big Dutch
Jun 9, 2015 07:49 PM
crowtoo
May 11, 2015 06:50 PM
McD
Apr 29, 2015 03:50 PM
Speedy
Jan 23, 2004 12:05 PM
