2000 Civic - no start
Old Apr 21, 2011
jennyak's Avatar
jennyak is an unknown quantity at this point
I turned my car off, ran an errand and when I got back in it wouldn't start. At all. Battery is fine. I can use the lights, blast the radio etc. The starter doesn't respond at all. No click. Nothing. So, I know what I need to look for but I wanted to throw this out there in case someone knows of a particular problem/wire/fuse that goes bad relatively often that would make my search quicker and easier. ...or the best way to go about checking the components... Thanks!
Old Apr 21, 2011
MelJ's Avatar
Trance Addict
Re: 2000 Civic - no start
Edit: If the starter isn't clicking, that might be it. There was a recall issued for the ignition switch for the 6th gen civics. The case with that is that the car would just shut off. It could be one of those 2 things. My car did something like this, but I flooded my engine. My car would crank, but wouldn't start. Doesn't sound like that's the case with you though.
Old Apr 21, 2011
jennyak's Avatar
Thanks...I went back to the car about 3 hours later and it started up just fine. Sounds like it will be a wild goose chase for the offending mis-connection...
Old Apr 21, 2011
in the meantime, this forum is for the 2012+ cars...
Old May 9, 2011
2EcuriouS's Avatar
2EcuriouS is an unknown quantity at this point
Yeah! It might be easy to find. If your vehicle is standard pump the clutch a few times before holding it in to try to start. If it will start sometimes with this proceedure the switch on the clutch under the dash may be out of adjustment due to so much shifting. If it is automatic run the shifter through the positions a few times before trying to start. The shifter switch may be off the transmission.
Old May 9, 2011
iSharix's Avatar
iSharix is a jewel in the roughiSharix is a jewel in the roughiSharix is a jewel in the roughiSharix is a jewel in the rough
I cant help you cause you're posting in the wrong subforum !
You blind !
rcolosi
Apr 29, 2015 07:48 PM
shawe90
Apr 14, 2015 07:10 PM
tattedlariat
Apr 12, 2015 07:55 PM
dubbc
Nov 7, 2001 02:24 PM
silvervtec01
Nov 4, 2001 06:56 PM
