Emissions Test - Failed "Please advise. Thanks
Old Apr 4, 2011
fernando97honda's Avatar
fernando97honda is an unknown quantity at this point
Hi, My 1997 Honda Civic HX failed it's Emissions Test. See below the ASM Emission Test Results. What do you suggest I do to get the car to pass the smog test? I'm thinking it's minor service or repair that I can complete. Thank you in advance.
1997 Honda Civic HX
ASM Emission Test Results:
15mph - RPM = 1587 %CO2 = 14.8 %O2 = 0.1
HC (PPM) = 53 (max 66)
CO (%) = 0.24 (max 0.57)
*NO (PPM) = 755 (max 487) (Failed)
25mph - RPM = 1705 %CO2 = 12.7 %O2 = 3.0
*HC (PPM) = 60 (max 49) (Failed)
CO (%) = 0.24 (max 0.55)
NO (PPM) = 678 (max 774)
Old Apr 4, 2011
MindBomber's Avatar
Live for the Twisties
Re: Emissions Test - Failed "Please advise. Thanks
Do the following and I can almost guarantee you'll pass.
Change your oil,
Replace spark plugs,
Replace 02 sensor,
Replace Cat *with a quality one*,
Adjust the idle to 1000 rpm,
Retard the timing by a couple degrees.
Before you go to the test:
drive till the gas light is on and fill up with 20L of Chevron 87 octane,
pour a 4L bottle of Methyl Hydrate in your gas tank,
take your car for a long, hard, abusive drive with the heater off to get your engine as hot as possible.
If your don't pass after that then you have no hope.
Old Apr 5, 2011
lazlong's Avatar
If you have an EGR clean it also. EGR problems are the number 1 cause of high NOx.
Remember, after you've reset the ECU to drive it for awhile to set the readiness codes before you go back for the inspection.
Old Apr 21, 2011
I'm making head way. I drove the car for 30 miles to heat up the CAT before taking it to smog station. Result where way better than before but I still failed the HC test. All the other test the car past with flying colors. Any advice? Fuel additive?
I have replace the PCV recently.
A compression check was performed and it passed. The reading were 160 from what I was told.
3. Fuel/air mixture too rich. Bad O2 sensor(s) can throw the fuel trim out of whack. They are now recommending changing the O2 sensors every couple of years now.
My reading for HC (PPM) where
Test 15 mph MAX 66 MEAS 75
Test 25 mph MAX 49 MEAS 49
What can I do without replacing the CAT or O2 sensor to get the HC to pass smog?
Greatly appreciate your advice.
Fernando.
Old Apr 25, 2011
asianboy781's Avatar
asianboy781 is a jewel in the roughasianboy781 is a jewel in the roughasianboy781 is a jewel in the roughasianboy781 is a jewel in the rough
02 sensor should last you 10 years or longer, my cat 02 has been there since 2000 and i never have to change it, i wait till it fail on me then to change it, have a good clean air filter, bad filter can reduce the amount of air going into the motor causing it to have more fuel and less air.
Old Apr 25, 2011
BlueEM2's Avatar
Whachya lookin at?
This stuff works! :
http://www.autobarn.net/ch05063.html
SimpleUser
Apr 24, 2021 02:54 AM
Civic15
18
Sep 19, 2017 07:48 PM
mjdiaz89
Jun 21, 2016 09:26 PM
CBRBlaize
Jun 17, 2016 06:11 PM
CivicsClass101
Jul 9, 2015 11:14 AM
