96-00 Replacement Hood Release Pull
Old Apr 4, 2011
akihiro_16's Avatar
akihiro_16 is an unknown quantity at this point
Hey guys, as many of you know the plastic release pull in the 96-00 civics tend to snap off. This is what I've come up with.
Leave me some comments and let me know what you think.
If you want to buy one check out my thread in the for sale section.
https://www.civicforums.com/forums/1...ml#post4528884
Left is 6061 Aircraft Aluminum & right is 316 Stainless Steel
Old Apr 4, 2011
Re: 96-00 Replacement Hood Release Pull
it looks like a good idea. i dont think it would work on the 7thgens tho since the release has a bracket bolted to the car frame so you can pull it. how exactly do you install this?
Old Apr 4, 2011
akihiro_16's Avatar
It's meant for the 6th gens which is the 1996-2000 civics since the 7th gens are 2001-2005. They have a different way to release the hood.
As for install you cut off the remaining plastic left on the small metal rod where the plastic used to be. And this slides over top and tightens on with a small screw.
usajags84
15
Aug 19, 2015 03:12 AM
crowtoo
May 11, 2015 06:50 PM
fabfive16
May 3, 2015 09:26 PM
cloudguy
Apr 28, 2015 05:02 AM
thesushiboy
Apr 12, 2015 02:54 AM
