96 EX civic cutting out
Old Mar 28, 2011
01Twinturbo's Avatar
01Twinturbo is an unknown quantity at this point
Ok so i have a 96 civic ex. It has been falling on its and bogging out lately. It seems to be worse when its cold. Also when i push the gas pedal futher it seems to fall on it face more. The lighter the throttle the better it seems to run. Car will set a CEL it is running to lean. I have replaced the plugs and wires and the upstream o2 sensor.
Any input would really help this thing is driving me nuts!!!
Old Mar 28, 2011
MelJ's Avatar
Trance Addict
Re: 96 EX civic cutting out
Have you checked for exhaust leaks, tested the MAP sensor? Bad tank of gas?
Old Mar 29, 2011
I have ran Several tanks of gas through it.. One had sea foam, and one had lucas fuel treatment. I have not check the map sensor yet. But i just had the exhaust checked out and there was a section that had some bad rust but i had that replaced. But the problem is still there.
What i find wierd is that it runs alot better when it warms up ( still deosnt run perfect but alot better)
Thanks
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
CarStuff
Dec 6, 2020 12:52 PM
usajags84
15
Aug 19, 2015 03:12 AM
Fastfebur
Apr 22, 2015 01:37 PM
doublins
Nov 11, 2001 07:01 PM
