trunk latch
Old Feb 26, 2011
TattooedFish's Avatar
TattooedFish is an unknown quantity at this point
trunk latch
I just picked up my car a couple days ago still working out bugs, one of them is that when I pull my cable to lift the trunk the latch just kind of springs up I don't really feel an tight tension on the latch. I crawled through the back seats unlatched the trunk and found the cable was not hooked up. So I hooked it up on the 3rd notch as tight as I could get it and its still way loose. Is there a way to tighten the cable or is it just wore out and needs to be replaced?
I wouldn't even care bout my key doesn't work either. I am guessing the seller of the car was in a rear end collision at one point and swapped out the trunk from another vehicle.
How can I get a trunk lock cylinder to match my ignition switch?
Old Feb 26, 2011
Newfiedan's Avatar
Newfiedan is a jewel in the roughNewfiedan is a jewel in the roughNewfiedan is a jewel in the rough
Re: trunk latch
where the latch attaches to the body there are 2 bolts loosen those and push downwards on it then retighten, give that a shot. I had to do that to mine to get it working.
Crazygrlinak
Oct 8, 2015 05:06 PM
Sep 27, 2015 11:33 AM
General DIY
Sep 25, 2015 08:02 PM
Skunkone
Sep 24, 2015 04:38 PM
nixyfior
Sep 14, 2015 08:32 PM
