00' Si po420
Old Feb 24, 2011
Em1 Vtec's Avatar
Em1 Vtec is an unknown quantity at this point
00' Si po420
Well I just got the car and I noticed that the inside smells like fumes when I drive it. Not even with the Vtec kicking in. It is still fine and drives fast like normal. No leaks or anything. I have the check engine light on and went to emissions, Of course I was going to fail. I never have anything like black smoke or anything. They told me it was the Cat. I went to An auto parts store to get a direct fit Cat. Will that work, and does it sound like just a "cat?" Oh and its a Magnaflow. Can anyone help? Thanks in advance.
Old Feb 24, 2011
MindBomber's Avatar
Live for the Twisties
Re: 00' Si po420
Cats wear out overtime, so the emissions testing people are likely correct, you may also need new 02 sensors as well.
Old Feb 25, 2011
MelJ's Avatar
Trance Addict
Re: 00' Si po420
My car threw the same code about a month and a half ago. I put fuel system cleaner in it, did some high rev driving and it hasn't come back on since . Maybe I got lucky? But if you're smelling gas, then it's probably toast. I didn't smell any gas when I drove mine.
Old Feb 25, 2011
Newfiedan's Avatar
Newfiedan is a jewel in the roughNewfiedan is a jewel in the roughNewfiedan is a jewel in the rough
Re: 00' Si po420
"I just got the car and I noticed that the inside smells like fumes when I drive it"
You have an exhaust leak , check all the exhaust mani bolts make sure they are tight then remove the heat sheild, chances are there is a crack there right around the 02 sensor bung area. You will not be able to see it with that sheild on there and it will trigger that code, next where the header meets the pipe check that donut gasket it can leak as well. Any exhaust leak from the primary to the secondary o2 sensor will trigger that code, same for a cat that is pretty much done. Hondas seem especially sensitive to this for some odd reason.
Old Feb 26, 2011
Em1 Vtec's Avatar
Re: 00' Si po420
Thanks alot you guys, it turns out the idiot who owned the can rigged it so bad. I had the cat replaced it was fried. Lol
Old Feb 27, 2011
Newfiedan's Avatar
Re: 00' Si po420
lol, well at least you got it looked afer.
Old Feb 27, 2011
Em1 Vtec's Avatar
Re: 00' Si po420
It just had its things here and there I will change, like he cut the springs. I want to get some to replace them and still keep a low ride height. Is there anyone that I can get that does not cost a pocket full, like Tein.
Old Feb 27, 2011
Newfiedan's Avatar
Re: 00' Si po420
teins are great, I have them on mine with dropzone struts, it works very well and its a comfortable ride. I know not everyone thinks dropzones are good struts but I have not had a hitch with them. Plus they do have a lifetime warranty.
Old Mar 1, 2011
Em1 Vtec's Avatar
Re: 00' Si po420
Can you tell me the exact set up you have please so I can get my ride right. Thanks oh and what's a good rebuild kit for a b16a2?
Old Mar 1, 2011
Newfiedan's Avatar
Re: 00' Si po420
tein s springs (they are green ones) and dropzone struts you can get them off ebay, with factory strut mounts. gives me about a 2" drop all around.
Old Mar 1, 2011
Em1 Vtec's Avatar
Re: 00' Si po420
Thank you I'll get some
Old Mar 1, 2011
asianboy781's Avatar
asianboy781 is a jewel in the roughasianboy781 is a jewel in the roughasianboy781 is a jewel in the roughasianboy781 is a jewel in the rough
Re: 00' Si po420
tein s tech are a way to go
i love em
Old Mar 1, 2011
Re: 00' Si po420
my car had a small leak right at the mid pipe
i would smell exhaust fumes and gas only when during crank
Old Mar 1, 2011
Re: 00' Si po420
factory oem rebuild kit
they have it at the stealer or ebay carry them too
Old Mar 1, 2011
Em1 Vtec's Avatar
Re: 00' Si po420
I just didn't want to get something that will blow my motor thanks
Old Mar 1, 2011
Re: 00' Si po420
you can buy honda oem parts off ebay they just third party seller
i find ebay the fastest way to find parts
the ones i order from provide honda part number so then i know that i aint getting the wrong part
Old Mar 2, 2011
Em1 Vtec's Avatar
Re: 00' Si po420
Do you know where I can get a si bumper and grille OEM is preferred thanks
Old Mar 2, 2011
MelJ's Avatar
Trance Addict
Re: 00' Si po420
You should try eBay first or hit up a junkyard. The former might be a better option depending on your location. I found an OEM side mirror with the motor and everything still attached for sixty bucks at a junkyard. I recently picked up an OEM bumper off of eBay for more than half off the dealer price. Both items are the color I needed as well. You can also try Craigslist.
Old Mar 2, 2011
Em1 Vtec's Avatar
Re: 00' Si po420
I'm looking, hey doesn't the Si bumper look diff from all the other 2000 and 99's?
Old Mar 3, 2011
MelJ's Avatar
Trance Addict
Re: 00' Si po420
I don't think so. I'd have to double check. When I went to compare prices for say, an EX, the part numbers were exactly the same. Those pieces are easily swapped, so they should just fit all the same. That mirror I got wasn't from an Si.
Old Mar 3, 2011
Em1 Vtec's Avatar
Re: 00' Si po420
Just making sure. What about the grille?
Old Mar 4, 2011
Re: 00' Si po420
i just got oem si front lip painted from the dealer 260
i compare them to my ebay front lip and the diffrence was like night and day
http://www.primepartssuperstore.com/...layCatalogid=0
thats the si grille
Old Mar 4, 2011
Re: 00' Si po420
front bumper all 99-00 civic is the same what set them diffrnt from an si
is that
the si have better grill and have front lip
i found the bumper off ebay painted for 225 bucks whiches ima order
since my recent bumper crack from hitting gaurd rail and snow bank
Old Mar 9, 2011
Em1 Vtec's Avatar
Re: 00' Si po420
Thanks alot, but did all Si's come factory with head lights?
Old Mar 9, 2011
Re: 00' Si po420
if u refering to all civic head light 99-00 honda civic head light is all the same
Old Mar 9, 2011
Em1 Vtec's Avatar
Re: 00' Si po420
big Type'o there Lol I meant did the Si's as come factory with fog lights?
Old Mar 9, 2011
Re: 00' Si po420
no 99-00 si came with factory fog light
it was an option but also made by an aftermarket company called raybrig
they also made the fog light kit for usdm integra type r, maybe they were jdm company that was put on civic sedans in japan
but i never went that deep in research though
Old Mar 11, 2011
Em1 Vtec's Avatar
Re: 00' Si po420
Thanks for clearing that up for me
civicfan247
16
Jan 30, 2012 05:40 AM
Snib
Jan 17, 2012 09:01 PM
adamcalgary
Jan 10, 2011 03:30 AM
deadliner
Mar 20, 2010 06:41 AM
Qthangcivic
Nov 9, 2006 09:39 PM
