cel problem.help ...
Old Nov 9, 2006
Qthangcivic's Avatar
Qthangcivic is an unknown quantity at this point
the car threw 2 code ;it was a P1298 and PO420 i looked it up to see what it was ,but dont known how to fix it,p 1298 was a high input voltage,and po420 it the catlic system.and the light it flashing 3 time when im crusing at 80 mph or so.any ideal guys.thank you........
Old Nov 9, 2006
d17acivic's Avatar
d17acivic is an unknown quantity at this point
P1298 - electric load detector (ELD) circuit high voltage.
More than likely a power wire is grounding out and so you may want to take a thorough look at your wiring and once you fix that problem check your under dash fusebox for a 7.5A alternator fuse and if it is blown replace it.
P0420 - Catalyst System Efficiency Below Threshold
More than likely one of your catalytic converters isn't working very well, or if you changed to a high flow catalytic converter or a test pipe then thats why your throwing that code
the P1298 might be a code to worry about but i wouldn't pay to much mind to the catalytic converter code unless where you live would have an issue with your emissions
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Luluharp
Sep 27, 2015 11:56 AM
Mannimarco
Sep 7, 2015 10:01 PM
dantheman42
Sep 4, 2015 01:10 PM
jpat21
Sep 3, 2015 11:32 PM
