96 dx 5spd first and reverse grind
Old Feb 11, 2011
cer0286's Avatar
cer0286 is an unknown quantity at this point
Hi All,
So as the title says, my 5spd tranny is having a grinding problem.
Sometimes when I take off in reverse I hear a light grinding sound, usually if Im putting more force on the car like backing up in the snow or up a slight incline , and yes the car is at a 100% dead stop when i put the car in reverse. I have also tried putting it in first or fourth gear before i put it in reverse. Also it does the same thing in first once in a while, as soon as I let the clutch out to take off I hear the same light grinding sound. It has been doing this for a few months on and off and im worried it is getting worse.
Like I said it is a light grind, much softer then an unmeshed gear grind.
I have looked everywhere online, and have not heard of this exact problem.
Thanks
Some car info:
96 civic dx 1.6 5spd
200,000
changed the mtf about 800 miles ago with honda mtf
no other gears grind at all..
Old Feb 11, 2011
Newfiedan's Avatar
Newfiedan is a jewel in the roughNewfiedan is a jewel in the roughNewfiedan is a jewel in the rough
Re: 96 dx 5spd first and reverse grind
check for wear in the shifter bushings also check and lube the clutch slave cylinder, and cv axles see if the boots are torn or if the cv axles have play in them. Short of that grab a sound or video clip of it and I will try to help you troubleshoot it.
Old Feb 14, 2011
asianboy781's Avatar
asianboy781 is a jewel in the roughasianboy781 is a jewel in the roughasianboy781 is a jewel in the roughasianboy781 is a jewel in the rough
mines make a grinding noise and its been getting louder even at idle
i changed throw out bearing and flywheel bearing
and a new clutch
heres a vid
as the grind can be heard
the only gear that i dont hear it on is 5th
either the road noise as taken over or i have a bad bearing in the tranny somwhere
i will wait till summer to take it off apart
but heres a vid see if urs are similiar to mines
and yes mines does make the sound at reverse also
http://www.youtube.com/watch?v=wvxcIPTscqg
Old Feb 14, 2011
its more like a whirrrring noise
Old Feb 14, 2011
Newfiedan's Avatar
try switching out to redline tranny oil, the oil that is in there now may be to thin and not lubing enough if the bearings are getting a little weak. you may have a slightly bent shift fork causing the issue, but I would give the redline a shot first see if that helps.
Old Feb 17, 2011
thanks i will check auto part store to see iif they have redline and if not i will order it online, all my gears shift in smooth and only 3rd gear grind if i punch it too hard but no gear pop.
Bonobo
Oct 2, 2015 06:58 PM
ThatGuy913
Sep 28, 2015 05:35 PM
Michael Durkin
Transmission
Sep 24, 2015 12:35 PM
Yang559
Transmission
Sep 21, 2015 01:41 PM
BBrosario
Sep 17, 2015 07:51 PM
