97 Civic Idle Problem! Gurus HELP!!!!!
Old Jan 31, 2011
strykker118a's Avatar
97CivicVtec
strykker118a is an unknown quantity at this point
Question 97 Civic Idle Problem! Gurus HELP!!!!!
Hey guys Im new to this site. I got my first Honda Civic yesterday and I got a good deal on it. Its just a DX 1.6 V-tec. All I needed to do to it was buy a battery and a caliper for it. All is good except for something to do with the idle. Like I said I got it yesterday and today when I started it, it would idle right and then jump to 2000 rpms and then down. 20 seconds later it would do it again. After it warms up it seems to be doing a lil better. Sometimes even being warm instead of idle jumping up, it drops a lil bt and then back up. What could this be? Any help would be appreciated. Thanks
Old Jan 31, 2011
MindBomber's Avatar
Live for the Twisties
Re: 97 Civic Idle Problem! Gurus HELP!!!!!
The problem is likely your idle air control valve, over time it can get dirty and cause problems with maintaining idle. All you need to do is remove it and clean it out and that should solve your problem.
Old Jan 31, 2011
97CivicVtec
I will try that. I also did a little bit of reading and I did replace my battery. disconnecting the battery resets ecu correct? If thats the case Im hoping it only did that cause it was the first start after disconnecting it. It should relearn how to idle correctly I hope.
Old Jan 31, 2011
Newfiedan's Avatar
Newfiedan is a jewel in the roughNewfiedan is a jewel in the roughNewfiedan is a jewel in the rough
It will relearn the idle on its own its not like some of the newer cars that have an idle learning process.
Old Jan 31, 2011
eatmyrice's Avatar
eatmyrice is an unknown quantity at this point
Its most likly the IAC valve. I literally had the same problem as you and solved it 15 min ago. Remove the iac and spray it with TB cleaner.
Old Jan 31, 2011
97CivicVtec
Talking Re: 97 Civic Idle Problem! Gurus HELP!!!!!
I will clean it tomorrow first thing in the morning and then take her for a ride. I dont think its a vaccum leak has to be a dirty iac. Thanks for info tho, helps.
Old Jan 31, 2011
eatmyrice's Avatar
This Youtube vid shows you how to clean it. You can remove the iacv from the TB or you can remove the TB altogether to get at it. I had to remove the whole TB afterwards because I couldnt get the iac gasket to stick vertically. You my have to replace the TB gasket if you chose that route.
http://www.youtube.com/watch?v=G-mwd5VJKt8
TXcivic2001ex
Air Conditioning
23
Jul 20, 2020 07:27 AM
beneditti
Jan 15, 2016 12:31 PM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
vtechcivic
Apr 21, 2015 06:58 PM
streetglower123
Apr 12, 2015 10:56 AM
