98 civic ex idle problem
Old Jan 24, 2011
ZachhhIsLegend's Avatar
ZachhhIsLegend is an unknown quantity at this point
after driving for a while when i come to a stop and have the car in neutral it starts to idle up to about 2000 rpms and then drops to about 500 rpms. sounds like its going to stall when it drops and lights dim drastically. any ideas?
Old Jan 28, 2011
Newfiedan's Avatar
Newfiedan is a jewel in the roughNewfiedan is a jewel in the roughNewfiedan is a jewel in the rough
Re: 98 civic ex idle problem
Check the battery terminals make sure they are all tight, clean and secure, also check and clean the engine ground straps and then in the engine bay check the fuse panel it has 2 philips head screws make sure they are tight. Next remove your intake tube and then clean the throttlebody with throttlebody cleaner, also check the condition of the air filter and all vac line while you are at it. High idle can be caused by a few things but eliminate the simple stuff first off.
TXcivic2001ex
Air Conditioning
23
Jul 20, 2020 07:27 AM
beneditti
Jan 15, 2016 12:31 PM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
vtechcivic
Apr 21, 2015 06:58 PM
streetglower123
Apr 12, 2015 10:56 AM
