97 Civic DX door beep problem
Old Sep 6, 2010
Pilgrymm's Avatar
Pilgrymm is an unknown quantity at this point
Whenever I open the door to my civic, the door beep thing goes off, regardless of whether or not the key is in the ignition, is this normal? I can't seem to find any dead fuses, or anything. Does anyone know what I can do to fix this?
Old Sep 7, 2010
jsmithe2010's Avatar
jsmithe2010 is an unknown quantity at this point
Re: 97 Civic DX door beep problem
U or the previous owner have done some electrical to it to affect it.
Old Sep 7, 2010
Pilgrymm's Avatar
Allllright... thanks Captain Obvious. Any ideas what? I'm a hardware technician and I'm usually pretty good at fixing these things, but I can't find where the noise is even coming from under the dash. This car is new to me, it was a gift from my mother-in-law (honestly she just wanted it out of her yard so she didn't look white trash).
Old Sep 7, 2010
02civicsi02's Avatar
Low and slow!
There is a thread on here that tells you how to stop the door dinger. He is the link to the thread maybe this will help you out some.
https://www.civicforums.com/forums/1...nda-civic.html
Old Sep 7, 2010
Mad Dog Tannen's Avatar
It is probably your key cylinder/switch is sticking. My friend ahd the same problem in his nissan. You could take the steering column apart and find the culprit or just disable the buzzer. Personally I would find the real culprit.
Old Sep 8, 2010
same happens on our old accord. its the lock cylinder sticking. usually i can take the key and tap the outside around the keyhole a few times and it will pop back out and the beeping stops. just try banging around the key hole til you hear a click. i dont feel like fixing cause then we need new keys for everything. its easier to just give it a few taps.
Old Sep 8, 2010
Pilgrymm's Avatar
I'll probably follow the previous thread that was posted up, but I was also thinking maybe a rubber mallet would work like what you described. not really into needless keying of the car if i don't have to. =)
TXcivic2001ex
Air Conditioning
23
Jul 20, 2020 07:27 AM
Ian SFBA
Interior DIY
Apr 25, 2015 02:25 PM
darwin-t
Apr 18, 2015 09:29 PM
Killagi
Apr 12, 2015 10:42 AM
NoToRiOuSxPiNoY
Bolt-on Engine Performance
Nov 7, 2001 11:19 PM
