cat converters
Old Aug 29, 2010
zowens26's Avatar
zowens26 is an unknown quantity at this point
Question cat converters
I have a 2000 civic ex with a few bolt on upgrades. I am about to have to replace the cat on it. Would my car still run like it should if I just get rid of it altogether or do I need to spend the money and replace it?
Old Aug 29, 2010
Mad Dog Tannen's Avatar
Re: cat converters
What state is it registered in?
Old Aug 30, 2010
zowens26's Avatar
Re: cat converters
Tennessee
Old Sep 2, 2010
02civicsi02's Avatar
Low and slow!
Re: cat converters
If you are in a area where the emssions do not care then you can just remove the cat and it will run fine. You will need a o2 sensor eliminator though cause without the cat the secondary o2 sensor will throw a code. The only thing the cat does is help smog and stuff. If you take it off you will experience alot of black sut on the back of your car. But if you want to just replace then thats your decision man. Its up to you.
Old Sep 2, 2010
Re: cat converters
High flow cats work very well but it's cheaper to just take it off.
Old Sep 4, 2010
anti-civic's Avatar
anti-civic is an unknown quantity at this point
Re: cat converters
just don't remove it if you have a straight through muffler or fart can. it will be way too loud, and draw attention to you.
on most vehicals there is little difference in performance, unless it's clogged up, but i doubt that.
if you are doing it for performance reasons, just spend your money on something else, you will see better gains for your money in a different area.
Old Sep 8, 2010
zowens26's Avatar
Re: cat converters
The main reason I did it was because it was clogged. It runs great. Better than it ever has. The only problem is the check engine light stays on. No big deal for the performance I got out of it.
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
Luluharp
Sep 27, 2015 11:56 AM
blizza
Sep 20, 2015 04:09 PM
Hollywoodsnake
Sep 20, 2015 12:58 PM
dantheman42
Sep 4, 2015 01:10 PM
