clutch problams
Old Apr 23, 2010
jmarks5563's Avatar
jmarks5563 is an unknown quantity at this point
clutch problams
so i have a 96 DX with a b16 swap from a 99 SI. the problem is that my clutch is messed up i dont know much about clutches or tranny's. its always let out late but all the sudden yesterday it had no pressure and is barley letting out all the way at the floor. i would really like to get some help with this please let me know>>> THANX
Old Apr 23, 2010
02civicsi02's Avatar
Low and slow!
Re: clutch problams
First does the clutch master cylinder have fluid in it.
Old Apr 23, 2010
jmarks5563's Avatar
Re: clutch problams
like i said im pretty dumb wen it comes to clutchs and transmissions so how do i check and were?
Old Apr 23, 2010
Low and slow!
Re: clutch problams
Its the little tank beside the the brake fluid tank. Just check to see if there is fluid in it. Its pretty simple just look at the tank and there should be a line up at the top and thats the full line, just check to see if where it is at. If you dont have any in there then thats your problem if not that. If you do then there can be a air bubble in the line. Bleed it then refill it. This is the first things I would check since its the most simple things and the cheapest.
Next would be is the tranni slipping at all. Is the rpms going down. If this is so then the clutch could be about to go out.
Old Apr 24, 2010
jmarks5563's Avatar
Re: clutch problams
i checked the fluid and it was not full barley any and very black. wehat kind of fluid do i need, how much were do i fill up and how do i bleed it or do i even need to.
Old Apr 24, 2010
Low and slow!
Re: clutch problams
If it barely has any in it then that is your problem right there. I had that happen in my old ej cause the clutch master cylinder was bad itself and the fluid just ran dry quick and the clutch would just drop to the floor. But anyway if it is like black then I would say bleed it. The bleeder valve is located at the bottom of the firewall near the tranni. there will be a little nipple looking thing and that is it. An easy way to find it is to follow the tank and down by the firewall and you should eventually find it. But you use brake fluid for the clutch master cylinder just like for your brakes. I always use the honda fluid.
Old Apr 24, 2010
jmarks5563's Avatar
Re: clutch problams
thanx i hope that works ill will let you know. but when i fill it up do i just fill the reservoir to the top or wat?
Old Apr 24, 2010
Low and slow!
Re: clutch problams
Ya you just fill it up till it hits the full line. It shouldnt take much.
Old Apr 24, 2010
jmarks5563's Avatar
Re: clutch problams
i followed the hard line and found the bleed off valve but i also noticed that there was a small leak from the part the the bleed off valve is located on do you think that would be that problam and if so what is that part
Old Apr 24, 2010
Low and slow!
Re: clutch problams
Ya if there is a leak then that will needed to be fixed or you will fill it up just to lose it all quick. And i am not to sure what part of it your talking about. Is it leaking in the slave cylinder. Here is a link to the clutch master cylinder at majestic. What exact part is it leaking from. Number 7 is the slave cylinder which is where the bleeder is.
http://www.hondaautomotiveparts.com/...LINDER+%281%29
Old Apr 24, 2010
jmarks5563's Avatar
Re: clutch problams
yea im pretty sure its the slave cylinder and i think i might be leaking from the master cylinder also so im gona have to replace both of them how hard of a fix are they
Old Apr 24, 2010
Re: clutch problams
buy a maintenance manual in any auto shop near you...
Old Apr 24, 2010
Low and slow!
Re: clutch problams
Its a pretty easy job. Just bleed it then its just the simple lefty loosy, righty tighty ordeal.
sesi
Oct 1, 2015 02:03 PM
ThatGuy913
Sep 28, 2015 05:35 PM
speedlever
Sep 24, 2015 07:18 PM
powman02
Sep 15, 2015 07:38 PM
Klame9420
Sep 7, 2015 10:03 PM
