fuel system help!!!
Old Apr 17, 2009
PAINT FREAK's Avatar
PAINT FREAK is an unknown quantity at this point
fuel system help!!!
Ok i am swapping my d16y7 with a d16y8 and i finished it a little while ago but the fuel pump is not coming on. I don't know if it is missing something to tell the fuel pump to come on or what. I also have an extra plug coming from my wiring harness that has nothing to plug to and I'm thinking that's what tells the fuel pump to come on. Also i don't have enough plugs on the ECU to plug everything up. The car is a 2000 civic Dx coupe and the motor came out of a 1996 civic Ex coupe. Someone please help me!!!!!
Old Apr 17, 2009
TRIZ's Avatar
Re: fuel system help!!!
You legally arent supposed to put an older motor in a newer car... You need to check to see if its legal before you go trying to get it to work right... also, are you using the 96's wireharness, or the orig 00?
Old Apr 17, 2009
It is legal in Louisiana. I have the 96 wire harness and PCM but i think i might need the fuse box from the 96. it has an extra plug coming off of the wire harness in the engine well that has nothing to plug into.
Old Apr 17, 2009
bump
Old Apr 17, 2009
TRIZ's Avatar
Hmmm... GO to a used car dealership and pop the hood on a 96 and see where it connects to. If its the fuse box, then pick up the correct box, if its something else, report back on what it is.
Old Apr 17, 2009
Ok ill do that.
vtecbrah
May 31, 2015 01:24 PM
PJ
Sep 5, 2003 01:00 PM
PJ
Jan 27, 2002 03:53 PM
htowncivicEX
Jan 21, 2002 11:48 AM
TaiChi
Dec 17, 2001 09:09 PM
