Broken trunk latch 2005 Civic
Old 01-08-2012
amystarfish26's Avatar
amystarfish26 is an unknown quantity at this point
I have a 2005 Civic with a broken trunk latch. It is the actual latch that is broken. First the spring fell out, then a cover plate. When I looked I could clearly see one of the plastic pieces that operates the latch is broken. If I manually manipulate some of the pieces I can get the trunk closed (hard slam). Can I buy this part to replace it and where can I get a manual that shows me how to do that? Thanks.
Old 01-08-2012
Re: Broken trunk latch 2005 Civic
Go here:
http://www.hondaautomotiveparts.com/
Select your exact car
Pick trunk lid from the menu
See picture, locate the part you want, look in the list.
Probably will be called LOCK, TRUNK (HANDLE)
See prices, order parts.
It's easy to replace. May have to adjust it just a little to shut right.
If you really need a book to figure it out, try the library. Many have access to online info systems.
Or just go to a shop or the dealer.
HTH
And look at this thread https://www.civicforums.com/forums/3...-all-time.html
carhag2000
04-25-2015 01:33 PM
cperez53
04-16-2015 09:31 PM
dano2005
04-14-2015 01:58 AM
Killagi
04-12-2015 10:42 AM
TopFuel
Exterior
11-13-2001 07:05 PM
Quick Reply: Broken trunk latch 2005 Civic
