High beam instrument cluster warning light
Old 03-18-2018
UncleB00M's Avatar
UncleB00M is an unknown quantity at this point
Hi all,
I had the annual car test today and was failed on the instrument cluster "high beam warning light" not coming on when the high beams are on.
Its passed previous tests without it being mentioned but I guess the tester today was a bit of a stickler
Anyway I need to get the light coming on...
I'm pretty sure its separate from the standard speedo lights so just wondering it a case of taking the cluster out, carefully opening it and swapping the bulb out? Or is it a bit more involved?
Any idea what kind of bulb I would need?
Cheers,
B
Old 03-18-2018
Slumpertcivic's Avatar
Re: High beam instrument cluster warning light
If replacing the bulb doesn’t work, you can rig up a simple LED taped to the dash getting power right off the headlight wire.
State laws almost always just require a dedicated indicator to be visible by the driver when high beams are on.
EM2 Bluez
02-03-2006 12:21 AM
liliechen
01-02-2006 10:15 AM
v8eaterokv6
Lighting
09-23-2005 11:38 AM
vietstylez
Lighting
04-13-2005 10:43 PM
T
03-10-2005 05:44 AM
Quick Reply: High beam instrument cluster warning light
