high beam indicator light
Old Sep 15, 2005
v8eaterokv6's Avatar
i have a new home do u
Question high beam indicator light
i hooked up my hids the other day and now i notice when my lights are on my high beam indicator light is on. but not all the way on just a little glow to it. anyone have any suggestions as to whats going on
Old Sep 15, 2005
alot of others had the problem its something with the kit thats wrong. If it bothers you, its just a bulb you can twist off and take out from the back of the cluster.
Old Sep 15, 2005
dirtySAMURAI's Avatar
I log in from time to time
the car is sensing that the high beam filament has failed and is warning you to fix it. that's my guess...
Old Sep 15, 2005
i was thinking the same thing is there a way to trick it
Old Sep 18, 2005
ragingSPAM's Avatar
I just burnt my tongue
yes when there is a short to ground or a short circuit or an open circuit to the highbeams the car sees that as something has gone wrong so it puts a little glow on the highbeam light...my eclipse did the same thing when i installed projectors on it cuz the harness on the car is was screwed up...so i fixed it
Old Sep 21, 2005
7thGenerasianCivic's Avatar
mine does the same except its full on high beam indicator blue. haha
Old Sep 22, 2005
streetglower's Avatar
I dont think thats why its on. I am pretty sure that when the highbeams are on, it completes the full high beam circuit which turns on the light indicating the high beams are on, when the low beams are on, the high beam circuit is open and the light is off. I may be wrong, but looking at the headlight circuit that what is seems. But then again, when you have HIDs, the circuit may be hooked up where the high beam circuit has a complete path to ground thus turning on the light.
Old Sep 22, 2005
correct^^. if you only have lowbeams, why does it matter if you have the light? Just pull out the bulb and be done with it.
Old Sep 23, 2005
AggressiveAdam's Avatar
AggressiveAdam will become famous soon enoughAggressiveAdam will become famous soon enough
Well, On my kit if I hit the high beams my HID's shut off, luckily my kit didnt spark the high beam light thing but i would have been pissed if it did. If you took out the light your HID's could be off w/o you knowing (then again you dont run your HID's during the day anyways, and you'll probably notice at night)
intensity
May 12, 2015 10:43 PM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
injencivic
Nov 9, 2007 02:31 PM
BoSS
Nov 27, 2001 04:55 PM
klam
Nov 19, 2001 05:46 AM
