cooling problem
Old Jun 19, 2003
AzNmiKex215's Avatar
2k1civic.com O. G.
cooling problem
well i got my trunk finished. the amp is now under the floor with a glass window. now to help with air circulation i mounted 3 computer case fans under the floor as well and cut out vents for the air to move.
for the power i thought i could just use the power from the remote wire becuase i only want the fans on wen the amp is on anyway. so i connect the power to the remote wire and use the same ground for the fans as i do the amp. (remote wire and fan power wire each have seperate conenctors and i screwed both connectors into the remote wire terminal on the amp)
works good.... UNTIL i wire my sub in. once the sub is wired in it sort of HUMSS. its kinda weird, its like it plays continuous low bass noise on/off . im sure it has to do with me sucking power from the remote wire.
anyway around it?
is there any other wire that gets power as soon as the key is in the "ON" position that is in or near the trunk?
if i just splice the fans power into the remote wire rather then conencting it to the terminal, would that fix it?
Old Jun 19, 2003
Regularjoe's Avatar
Regularjoe is on a distinguished road
A relay might help. But I dunno.
Fans are dirty electrically. Make sure the wires are away from the RCAs too.
Old Jun 19, 2003
2k1civic.com O. G.
power is definitely away from the rcas. a inline relay? do they have them at radio shack?
Old Jun 19, 2003
dups's Avatar
dups is an unknown quantity at this point
I'd bet its because you're using the same ground for the fans as you do for the amps. I might be wrong, but I don't think you should do that. And I think maybe splicing it might fix it. But my first guess is because its sharing a ground.
TXcivic2001ex
Air Conditioning
23
Jul 20, 2020 07:27 AM
Reginator
Jun 13, 2015 02:28 PM
Lopes101
Jun 7, 2015 08:04 PM
brian257
Jun 4, 2015 08:17 PM
dinsum
May 28, 2015 09:30 PM
