Xm Diy
Old Jun 11, 2003
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
Xm Diy
Tools needed
Screwdriver
Ratchet set
Exacto Knife
Panel Popper
Various Zip Ties
Equipment Needed
XM ready Headunit
XM controller
XM antenna
Step 1:
Remove Headunit / Climate control pod, run cable from passenger foot area to area behind headunit. use T-tap to connect +12 volt on IP Bus cable to yellow wire in headunit harness
connect IP Bus cable to Headhunit and replace pod. connect other end to controller, connect antenna, and touch ground wire to vehicles body. turn on car and switch XM to channel zero and verify you can here the xm broadcast before installing everything else.
Step 2:
unhook controller and run IPBus cable to intended mouting location. i ran mine under the passenger door sill, behind the plastic "wall" and into the trunk.
Step 3:
Determine mounting location on roof for antenna, its really personal preference on this step
Step 4:
here comes the fun part, conceling the antenna wires. the antenna is split into two wires, one for terrestial reception and one for satellite reception. this makes it much easier to install. if you look under the gasket that surrounds the rear window, you can see theres space under it, just enough to stuff the wire under it. the best tools to do this is the exacto knife and panel popper. the knife is kind of a risk, i didnt have anything that thin that didnt have a sharp edge, so i used the dull end of the kife to pull the gasket back some enough so i could stick the wire in, then pushed the wire down the gasket length with the panel popper, it makes much more sense when you actually start doing it. just be patient with it, or youll be
Step 5:
How to get the wire into the trunk? the only way i could think is zip tie it to the trunk arms
i know this isnt the best way. I'm open on suggestions on other ways to do it.
Step 6:
once controller is mounted, i chose to mount it on the back of the 1/3 seat using zipties. (i've since then cleaned up the cables) Connect eveything and turn the car onto XM and tune to channel 0. If you've gotten this far and you can hear the XM broadcast, congrats! youve done the install correctly. copy down the radio ID thats displayed on your headunit and then logon to www.xmradio.com to activate your unit. once its activated, about 10 consecutive minutes of having your car tuned to XM, you'll be able to receive all 100 stations. until your activated, one station from each category is broadcasted.
Step 7:
sit back and enjoy XM
the antenna is barely noticalbe if your facing the front of your car
Any questions or comments, email me. webmaster@grenlochfire.com
Old Jun 11, 2003
konstanting's Avatar
konstanting is an unknown quantity at this point
can u get a pic fomr the back of the car? this looks very nice man, congrats. i was wondering if u had to subscribe to the xm service but i guess u do.
nice DIY!
Old Jun 12, 2003
ill get the pic later today, you dont really have to subscribe to XM, if you dont subscribe youll still be able to hear about 7 channels
Old Jun 12, 2003
here ya go
Old Jun 14, 2003
KeNsHiN's Avatar
LEVA
thanks!!
Old Jun 15, 2003
ZMan2k2's Avatar
The Man, Myth and Legend
From: Western Canada, where the beer is cold and the women are HOT!
ZMan2k2 is an unknown quantity at this point
Good job man! Nice DIY. I just have one question though. Would it be possible to mount the antenna on say, the dash of your car, on the inside, so you don't have to worry about the wires, or some punk beating or theiving your antenna? Or does it specify in the instructions that it has to be on the outside of the car?
Old Jun 15, 2003
the directions say that for proper reception, it needs ~2 square feet of metal to be mounted onto, thats why they can make the antenna so small. if your worried about wires, theres a through the glass antenna, but i dont know how well that would work if you have tint on your windows. another member on this board mounted his on the rear deck, that might be an option
Old Jun 15, 2003
ZMan2k2's Avatar
Cool. Thx man. I've gotta look into it more now.
Old Jun 15, 2003
anyone have any better ideas for how to get the wires into the car from the antenna?
Ziggy1999
Oct 15, 2015 07:56 PM
General DIY
Sep 25, 2015 08:02 PM
meicalnissyen
Sep 25, 2015 12:12 AM
speedlever
Sep 24, 2015 07:18 PM
henrytn
Aug 11, 2015 10:01 PM
