Capacitor charging
just unhook your fuse up front, wire everything up and reinstall your fuse. there will be a spark and now your cap is charged. or you can use be between a 60-100 ohm resistor or it will take forever.
If I were you, I'd goto REadio SHack, buy 1 pack (i thknk you get 5 R's per pack) of 600 Ohms, and twist all the ends together, this way you get a fast charge/discharge and you wont exceed the power ratings of those 1/10th W resistors.
Guys, I'm bringing this post back from the dead because I really, really need to find out what ohm resistor i need to discharge my 1 farad cap.
A pic of the resistor would do fine too.. i can id it by the color scheme..
thanks..
thanks..
I think you should just use a light, that'd be the easiest way. Just connect it in series and hook it up to the battery. It'll go out when it's fully charged.
If you really want a resistor.. they already answered your question above.
I dont want to "charge" the cap. I need to "discharge" it.
And I ask because I am getting mixed opinions on the proper ohm resistor.
One person said a 1k resistor
another one said 60 - 100 ohm
and the last one said 600 ohm..
that a pretty large range and I dont want to damage the cap.
thanks
thanks
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
haloway13
Nov 6, 2015 10:43 AM
Skunkone
Sep 24, 2015 04:38 PM
JMKendrick
Sep 16, 2015 06:17 PM
h4ldol
Sep 10, 2015 12:25 PM
