Solder or Crimp?
Old May 4, 2003
MangoEX's Avatar
Just Be
MangoEX should not be trusted
Solder or Crimp?
When wiring audio (amp, hu, etc) is it better to crimp or solder the wires? I really never seen professional shops solder wires... anyway.. thanks for your input.
Old May 4, 2003
ZSKCivic01's Avatar
Extreme Member
ZSKCivic01 is an unknown quantity at this point
I would recommend soldering the wires. The reason I say that is because soldering the wires guarantees that the wires will never come undone. When crimping them, there is always the possibility of the wires coming apart. The professionals crimp the wires so they can get them done quicker, so I would just take the extra time and solder the wires to ensure that they will never seperate.
Old May 4, 2003
MangoEX's Avatar
Just Be
Is that the only reason? Cause my crimping is pretty damn reliable. I thought maybe it would have to do something with sound quality or something? Someone shed some light on that?
Old May 4, 2003
bzrollin's Avatar
bzrollin is an unknown quantity at this point
Soldering the wires is much more reliable, even if the wires are pulled on - i guarantee if i were to pull on wires that were crimped, they would become unattached at the crimp. On a soldered joint, the connection is actually stronger then the wire, the wire would break before the joint. Things like alarms should always be soldered. Radios arent as important i suppose,you wouldt notice any difference in sound quality. Crimping is a little faster, thats all.
Old May 4, 2003
ZSKCivic01's Avatar
Extreme Member
Either one won't make a difference in sound quality. Both will connect the wires and complete the connection from the HU to the speakers the same way. It is just that crimping has the potential to come loose.
Old May 4, 2003
OyD's Avatar
OyD
OyD is an unknown quantity at this point
If you crimp properly they won't come undone. I can't think of anytime that any of my wires gets tugged on enough to pull them out of their connections
Old May 4, 2003
MangoEX's Avatar
Just Be
Yeah mine too... i tried undoing a crimp i did cause i spliced the wrong wires, so i pulled and pulled and the wire itself snapped. i have a good crimping tool.
Old May 5, 2003
OMega's Avatar
OMega is an unknown quantity at this point
Actualy soldering gives you the best of both worlds strenght and ability to undo your work.
Old May 6, 2003
OHERC's Avatar
OHERC is an unknown quantity at this point
soldering provides less resistance also. A crimp 99% of the time will have more resistance.
Old May 6, 2003
Spider883's Avatar
9K Redline Owns U
soldering and shrink wrape rules
Old May 7, 2003
darklegacy540's Avatar
darklegacy540 is on a distinguished road
Solder, Heat Shrink, Tape!!!!
Old May 7, 2003
VNlilMAN's Avatar
The Standard One
hell naw, twist and then tape.. forget crimping and soldering...
lol i know ghetto but hey i had no problems for a year and a half now...
Old May 8, 2003
Taffy's Avatar
Taffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant future
Solder if you have $15 for the tools..
Crimp if you have $5 for the caps and crimper...
Tape if you have $2 and are ghetto...
Mc7602
Sep 17, 2015 02:01 PM
shaejb15
Sep 3, 2015 01:35 PM
mac25
Aug 21, 2015 11:14 PM
jnissen
Aug 9, 2015 05:34 PM
sch2cm
Jul 21, 2015 09:58 PM
