help part 2
Old May 2, 2003
corruptnu2's Avatar
corruptnu2 is an unknown quantity at this point
help part 2
was just wondering were and what u guys grounded your ground wire to when hooking up your amps. I have my amp in the trunk. Pictures would be greatley appreicated. Thanks
Old May 2, 2003
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
trunk
Injen
Old May 2, 2003
prototype's Avatar
x-factor
i just grounded mine to the chasis...pull up the carpet and screw it into there.........
moved to i.c.e. forum
Old May 3, 2003
tbone323's Avatar
tbone323 is an unknown quantity at this point
there is a location in the trunk, just to the right of the trunk latch, where all of your trunk electronics are grounded. You can take that bolt out and add your ground wire to there.
Old May 3, 2003
AntDeezy's Avatar
i grounded mine to the latch that holds the trunk closed - up under the plastic it was a pain in the *** to do it but looks hella clean...
Old May 3, 2003
tbone323's Avatar
if you're gunna ground it there, you may as well use the grund location of the factory electronics like imentioned above
Old May 3, 2003
DizWikedCivic's Avatar
u can try the selt belt bolt, spare tire bolt or drill a new gound
Old May 4, 2003
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
i drilled my own ground, the stinger wiring kit i bought had this ground attachment, it had a hole for the 4 guage wire then two "feet" that bolted to the car, it works pretty well
mohawkboom
67
Aug 25, 2015 12:28 AM
Tim1959
Jun 3, 2015 08:15 PM
juror
May 26, 2015 06:35 PM
shindrome
Exterior
May 5, 2015 02:50 PM
Thriftmaster
Vancouver
Apr 28, 2015 06:02 AM
