quick amp question
Old Apr 27, 2003
AzNmiKex215's Avatar
2k1civic.com O. G.
quick amp question
hi i have a rockford fosgate 800 punch A2 amp.. i have a power question. on the side where u connect the power and negative. each part has two hole to put wires into.
like this
POWER
O O
GROUND
O O
my question is do i split the power wire and negative wires in half to use both holes? or do i just just one of the holes for power and just use one for ground?
Old Apr 27, 2003
JohnDoe's Avatar
JohnDoe is an unknown quantity at this point
you need 2 power wires.
Old Apr 27, 2003
2k1civic.com O. G.
so i need to have two wires comming from the battery? what the hell.. i always thought u would have just one big one.
Old Apr 27, 2003
JohnDoe's Avatar
you need one 4 guage from the battery, into a distrobution block, from the block into 2 8 guage wires to the amp. the ground wires too.
Old Apr 27, 2003
Falcon's Avatar
Falcon is an unknown quantity at this point
you COULD run two 8 guages from the battery.. assuming you already went and got the 8..
i dont think it matters
but if you have the choice.. go with the dist. block
Old Apr 27, 2003
2k1civic.com O. G.
thankz guyz
Civic65
Jul 19, 2015 10:13 AM
NoobyKid
Jul 13, 2015 07:53 AM
phantommaggot
Engine start problems
Jul 12, 2015 12:55 PM
Bill in San Jos
Jul 10, 2015 12:32 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
