RCAs behind HU
Old Apr 25, 2003
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
Question RCAs behind HU
i took my headunit / AC control pod out yesterday so i could hardwire my stobe light, (no the apc ones, im a volunteer firefighter). so when i put it back, their was more interference comin outa my speakers. the only reason i can think of is that the rcas are touching each other, and the ground of each cable is coming in contact with each other. would that be a reason for the increased interference? can i wrap the connections with electrical tape to stop it? thanks for your help.
Old Apr 25, 2003
reytito's Avatar
i doubt its the rca's...they are heavily sleeved wires.
Old Apr 25, 2003
im talking about the actual connection between the rcas i ran and the pigtails coming off the headunit, the gound sleeve on the rcas are exposed, and i think when they touch its causing interference
Old Apr 25, 2003
SiCoupe's Avatar
SiCoupe is an unknown quantity at this point
My bet is that your noise is comming from switching signal to your strobe lights. If it only does it when they are on that's your problem, good 'ole EMI.
Craig (Elec.Eng)
Old Apr 25, 2003
it does it intermitenly (sp?) regardless if the strobe is tunred on or not
Old Apr 25, 2003
WhiteRabbit's Avatar
yeah, its funny how that kind of stuff works. I once grounded an FM modulator to a radio direct once, and then teh AM signal dropped out. reground to the body, presto! works great!
yoru radio needs its full power, for sure
Old Apr 25, 2003
fonto's Avatar
The LA Clipper
I had the worst noise problem about 6 months ago...and i did everything to try and correct it...and tried regrounding everything!! Anywayz to make a long story short, someone on the site suggested to jiggle the wires around behind the HU and reinsert it...and Walla, it worked!!! So try jiggling your wires a lil...ya never know.
redcloud
Sep 7, 2015 01:45 PM
redcloud
Aug 26, 2015 11:27 AM
STang57
Oct 20, 2002 02:41 AM
ZVotypka
Apr 30, 2002 02:45 AM
nochopstix
Mar 26, 2002 06:15 PM
