Stock Crossovers
Old Apr 25, 2003
zzjkimzz's Avatar
zzjkimzz is an unknown quantity at this point
Stock Crossovers
Does anyone know the location of the stock crossovers in an 03 Civic EX coupe? Thanks.
Old Apr 25, 2003
Mystic3030's Avatar
Yup, i'm an A$$hole.
There is no crossover, there is a bass blocker wired inline with the tweeter. If you take your door panel off, you will see it about 4 inches down the wire from the tweet. It should be wrapped in a peice of foam, and is about an inch long.
Old Apr 25, 2003
zzjkimzz's Avatar
If im installing a new set of components, would it matter if I just used the tweeter wiring with the inline bassblocker, or should I replace this wire with aftermarket?
Old Apr 25, 2003
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
if your buying new components, they should come with a crossover that will seperate the signals and route them to the right component
Old Apr 25, 2003
zzjkimzz's Avatar
Yes, I have a set of Infinity Reference 6000cs componenets with crossovers. I just wanted to know if I should cut out the bassblocker or just leave it there when I wire the crossovers to the tweeters, because I am going to use the stock wiring already in the door.
Old Apr 25, 2003
Mystic3030's Avatar
When you unplug the tweeter, the bassblocker comes out with it. It's attached to the tweet, not the wires in the door. You should be all set.
Old Apr 25, 2003
zzjkimzz's Avatar
Cool, thanks. Is the wiring in the door pretty straightforward, i.e. the colors/polarities match up with what the manual says?
Old Apr 25, 2003
Mystic3030's Avatar
There is a wiring/color diagram in the DIY section on this site. Generally light colors are + and dark colors are -.
Misfit2613
Jul 30, 2015 09:49 AM
NoobyKid
Jul 13, 2015 07:53 AM
Jul 12, 2015 11:54 AM
BootyDo
Jul 7, 2015 06:06 AM
7thgensurvivor
Jul 5, 2015 12:17 PM
