JL 12w3 Sub Repairable?
Old Apr 21, 2003
ZSKCivic01's Avatar
Extreme Member
ZSKCivic01 is an unknown quantity at this point
Question JL 12w3 Sub Repairable?
Hey everyone, im really irritated after what happened today. I was driving around listening to music and my sub all fo a sudden stops working. I take it out of the box and I examine it closely, and I notice that one of the negative wires coming out of the cone and onto the plate where you connect the wires coming from the amp to the sub is broken. It was severed right where it connects to that plate,r ight where there is that protective gel around the connection. All of the other connections seem to be connected so I try to solder the broken wire, well, I connect it back up to my amp after that and my sub works, but it makes a very loud popping noise, like something is hitting the cone. The reason I think it does that is because the solder doesn't make the wire flexible and the power wire has to be able to flex up and down with the cone. So my question is that if I bring it to a speaker repair place, should they be able to repair this wire?
Old Apr 22, 2003
ZSKCivic01's Avatar
Extreme Member
Nevermind, got it fixed.
solarpunk70
Apr 12, 2016 11:43 AM
cferry7
Oct 18, 2015 06:32 PM
Sep 27, 2015 11:33 AM
curaze
Sep 22, 2015 08:27 AM
pilebuck13
Sep 21, 2015 10:45 PM
