PS2 HU Controller?
Old Apr 7, 2003
evilone's Avatar
The Nightraid crew - Sensible Ownage
evilone is a jewel in the roughevilone is a jewel in the roughevilone is a jewel in the roughevilone is a jewel in the rough
PS2 HU Controller?
I got this idea over the weekend, would it be possible to use a PS2 controller for a head unit? I was thinking about putting the HU under the seat if possible ('74 F250, don't ask), and I wanted something REALLY custom...I was thinking if you drilled the circuitboard on the controller and the faceplate and ran telephone cable, it might work. Any opinions?
Old Apr 7, 2003
LudlamTheory's Avatar
i boogie for the raindrops
eh.... it might... it might not. youd need to find the exact signal that is sent to the button when pushed, you also need to find out what kinda electronics are goin on in the ps2 controller. basically, it would be excessive amounts of work
Old Apr 8, 2003
sadboy916's Avatar
HISPAnIC CAUSIn PAnIC
whoa... i doubt it
Old Apr 9, 2003
WhiteRabbit's Avatar
sur eyou can. i built a similar model, actually, hacking into teh remote. what you do, is hack yrou remote and use micromini relays to act as switchesfor the remote itself, then solder those in.
then you need to find where yoru controls are coming from, like, say, your steering wheel controls for cruis control and your power window switch controls.
then you add relays in those buttons, powered by the cruiscontrol on/of switch and the center pole of the window switch.
then simply wire it all up and place the remote where it will be visible to the radio.
in yrou case it will be a breeze, you wont have to hack anything in teh car! use the isolated ps2 controller (youll have to hack it to death) to fire teh relays in teh remote (youll have to hack this one gently ) and when everythign is set, itll work flawlessly.
Old Apr 9, 2003
got the idea from someone who hacked into thier power mirrir adjustor that was on his door panel to control volume up/down and track advance/previous
Old Apr 11, 2003
evilone's Avatar
here's what I'm thinking...http://www.imagestation.com/album/?id=4290370469
Old Apr 11, 2003
were not allowed to see that....
h4ldol
Apr 24, 2017 08:16 PM
robjcivic
Mar 12, 2017 12:10 PM
Tedverseti
Sep 29, 2015 05:41 PM
