Stock HU power output per channel
02 EX stock CD HU with six speakers, whats the total power and per channel. Please answer only if you know for sure, I heard Honda rated it at 200 watts total
lease: . I'm thinking about replacing the speakers and thats it, no amp, no sub, just speakers. period. Thanks.
Originally posted by LudlamTheory
SEARCH!
this has been covered 148 times in the past.
and no, its not 200 watts, its not even 100 watts, its something around 10-14 rms per channel.
SEARCH!
i boogie for the raindrops
ok. i said 10-14 rms per channel. Even if you buy a HU that says 55x4, look at the fine print, the largest number you will EVER see is 22 rms x 4. Now add to this, that in order for a standard din sized unit to hold cd readers, processors, everything AND contain mosfets to power yor speaker, its gonna have to be a tiny amount of em, and prolly not the best quality ones to begin with. Now lets say your deck DOES say 22 rms x 4, lets say it really does put that out, but theres no way an area that small can produce that much power and keep it clean, so therefore the highest amount of power you will ever see from it is probably around 15 rms. Section 2, teh stock HU. Now even if you did see it say that, its probably the infamous max power which you should play off as if it didnt exist anyways.
Forget this. Bah.. this aint worth it. I have explained it before...
cloudguy
Apr 28, 2015 05:02 AM
