Using an inverter at a indoor show o run TV's
Old Mar 23, 2003
Rollin0n18s
Guest
Posts: n/a
I am going to a indoor show in boston ma april 11th, and one of the rules is you have to disconect your battery. So i thought i wuld,nt be able to run my tv's underbody neons and the rest of the12volt stuff. I was speakking to a guy that has done alot of indoor shows and he said to get a inverter and pay for electricity when i register for the show. I guess my question is how could i run my 12 volt stuff using a inverter?
Old Mar 23, 2003
Ed's Avatar
Ed
I don't think you'll want an inverter, you'll want a 120 to 12 volt converter, like a big *** AC adapter. Then you can run your neons and such off the wall.
Old Mar 23, 2003
WhiteRabbit's Avatar
thats probably what he meant by inverter. unfortunately, they arent cheap, and powersupplies are not cheap either.
radioshack sells a 10 amp 12 volt powersupply for $100, should be enough to run most of your lights just fine, you can get bigger supplies if you want to run your stereo as well, they just get more costly.
ebay i believe you cna get 12 volt power supplies cheap too.
Burnout
Jul 15, 2022 10:24 PM
dinsum
May 28, 2015 09:30 PM
McD
Apr 16, 2015 10:46 AM
ALLMAN
South
Dec 6, 2001 01:05 PM
supercivic01
South
Nov 30, 2001 11:27 AM
