Review: Fatmat hoodliner/Fatmat
Old Mar 22, 2003
Mystic3030's Avatar
Yup, i'm an A$$hole.
Thumbs up Review: Fatmat hoodliner/Fatmat
OK, so I got my Fatmat and my Fatmat aluminum backed hoodliner today....got the drivers side door fatmatted (3 layers...2 on the outer sheetmetal, and 1 on the layer part that touches the interior panel. I also installed the hoodliner.
I noticed a pretty significant difference in road noise on my side of the car with just the door being fatmatted, as well as no more door rattle from the music, and my sideview mirrior has stopped shaking. The Fatmat does seem to be slightly thinner than Dynamat Xtreme, but you can double/tripple layer, and it'll still be cheaper than Dynamat. I paid $290 for the hoodliner and 200 Sq. Feet of Fatmat, shipped to my door. That price would get you about 40 sq. feet of dynamat.
As for the hoodliner, BUY ONE FOR YOUR CAR RIGHT NOW. Cruising at 90 MPH around 4,000/4,500 RPM range the engine noise is almost undectable. I am very very very impressed with this product. Massive reductions in engine noise...simply incredible.
So overall, i'm quite happy with my purchase. Also included in my order were 3 utility knives, 3 rollers, and 3 packets of concentrated degreaser/surface prep stuff at no cost.....My order was shipped on Tuesday, and I received it today (Friday) so there is a quick delivery time, not to mention the customer service from the company is excellent.
OK, that was a bit more long winded than I expected, but oh well.
-Mystic
Old Mar 22, 2003
Ed's Avatar
Ed
Thanks for the info I've wanted to decrease the engine noise, how difficult to install was it? Are there any tools that you feel were necessary, rollers, etc? thanks!
Old Mar 22, 2003
KeNsHiN's Avatar
LEVA
yea, i need something to reduce the road noise! i travel at freeway speeds all day and it gets so loud............pisses me off. I will look into fat mat and thanks for the info. BTW- install , could you write up a DIY??
thanks
Old Mar 22, 2003
custom2k1's Avatar
custom2k1 is an unknown quantity at this point
I noticed quite a difference after fatmatting my entire car but the only problem with it is the smell. Its been almost a month now and it still smells like the day i put it in. Anyone having the same problem or any idea of how long the smell lasts?
Old Mar 23, 2003
Mystic3030's Avatar
Well, my car is sitting in the garage right now, completely stripped....::sighs:: it'll be done tomorrow....2-3 layers on every surface. Anyway, the install for the hoodliner is pretty simple....the hoodliner comes with a peice of fatmat to cover the hood, and the liner. You just prop the hood up, clean it, cut the fatmat to the correct size, apply it, then wipe that clean, and cut and apply the hoodliner ontop of that. Takes about 35 min to an hour depending on how used to this kinda stuff you are. Included with almost every purchase are a razor, a roller, and a degreaser compound.
As far as a DIY, you really dont need one....just strip everything out of the car (seats, panels, carpet, etc.) vaccum/deagrease it, and put the fatmat down.......
Old Mar 23, 2003
Dr5D's Avatar
dosent the hood liner hold in heat or somthing? seems like a not so good idea? seems good that it cuts the engine noise tho. i thought that noise mostly came thru the fire wall
Old Mar 23, 2003
Mystic3030's Avatar
There are two hoodliners available....one has an aluminum facing that reflects heat back down into the engine compartment, and one that has a black urethane facing that absorbs the heat and radiates it out the sides of the hood....but honestly dude, you have a civic....it's really not gonna matter.
As far as engine noise coming in through the firewall, yes, thats how some of it gets into the car, but the hoodliner absorbes so much of it, that there isnt much left to go through the firewall. Go pop the hood on a more expensive car sometime and notice the padding and **** under the hood....it's basically the same idea.
Old Mar 23, 2003
Ed's Avatar
Ed
I just read that the foam is 3/4" thick, was that difficult at all to install? When the hood was closed, did it interfere with anything in the engine bay? Was there any reason you bought the aluminum backed over the urethane one?
Old Mar 24, 2003
SOHCScreamer's Avatar
SOHCScreamer is an unknown quantity at this point
can i just line the underside of my CF hood with Dynamat? will the work to reduce road noise?
Old Mar 24, 2003
Mystic3030's Avatar
I chose aluminum because the guy I spoke to over the phone said thats the most popular one... ::shrugs:: As far as it being difficult to install, not at all. You just peel the paper backing off, and stick it to the hood. There are no issues with it interfering with anything under the hood, the only thing you gotta be careful with is to make sure you dont cover the hole for the hood prop, and the washer nozzles.
You really can not just put dynamat or fatmat on the hood because the heat from the engine will melt the tar. (fatmat is made of tar/asphalt). The hoodliner comes with a big peice of fatmat to put on the hood, then you put the liner over that. T
Old Mar 24, 2003
Mystic3030's Avatar
Old Mar 25, 2003
Frank2sy's Avatar
Frank2sy is an unknown quantity at this point
How much for just the hood liner, and where did you got your Fatmats? Was 200 sq. ft. of Fatmat enough to cover your whole car?
Old Mar 25, 2003
Mystic3030's Avatar
I think the hoodliner is $49....+ shipping. Your best bet is to buy everything you want from them at once, and talk them into only charging you once for shipping. 100 sq. feet is enough for your car if you are doing one layer....I did 3 in my doors, 3 on the side panels, 2 on the floor.....and I will be doing my trunk in 3 layers so I needed 200....i'm not even sure if thats gonna be enough.
ZSKCivic01
Jan 31, 2005 08:00 AM
opto_isolator
Aug 12, 2003 07:59 PM
tom1178
Jun 28, 2003 03:05 PM
ZSKCivic01
Mar 25, 2003 04:39 PM
hondah1
Feb 18, 2003 06:19 PM
