alternate way to wire speakers to an amp
Old Feb 23, 2003
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
i was helping my friend install his ice in an eclipse. he had a four channel amp and wanted to hook them up to his speakers. the speakers were allready installed so i thought it would be easier to tap into the wiring harness behind the headunit then pulling off the door panels and running it through the boot of the door. well i hooked everything up and no sound from the front. i hooked it up by cutting the wiring harness between the new hu's half and the metra half of the harness and hooked the new cable from the amp into the metra half. was that the right way to do it?
Old Feb 23, 2003
LudlamTheory's Avatar
i boogie for the raindrops
it can be done that way, though not reccomended...
Old Feb 23, 2003
so best way would be to pull the door panels and run new cable?
hes only pusin 60 watts per speaker
Old Feb 25, 2003
BlueTroll's Avatar
BlueTroll is an unknown quantity at this point
60watts??..... definately.
Old Feb 25, 2003
aldini's Avatar
aldini is an unknown quantity at this point
what about 45 watts per speaker? and if so? will it be a noticable difference?
jru27
Jun 19, 2015 03:51 PM
jackoncruzpr
May 24, 2015 12:24 AM
Cross
Bolt-on Engine Performance
Apr 3, 2002 03:00 PM
OPGForce
Feb 7, 2002 09:43 AM
Cypher
Dec 30, 2001 07:09 PM
