AEM Pulleys, a joke, hassle or the best?
Old Jan 8, 2002
Cross's Avatar
Cross is an unknown quantity at this point
I got some AEM pulleys and I don't know exactly what went wrong but I installed them correctly. Apparently I didn't check up too much on them first. After installation they don't work the alternator as hard, therefore the alternator didn't push alot of juice. Every stop light I had to rev my engine to keep my JL Audio Sound System going or my car would die. A few times I had to be boosted off. I guess if I didn't have a great sound system I would be good to go. But I've heard from another guy his car runs fine, but hes using a only Pioneer CD deck with no amps or big speakers. Unlike me and my 12s and 2 high powered amps. So just note this before you spend $140...
Randy
Old Jan 8, 2002
mikalem's Avatar
mikalem is on a distinguished road
You could always offset that problem by getting a high performance alternator..... it would probably help out in that situation
Old Jan 8, 2002
Cross's Avatar
Whoa a whole $1300 for high performance alternators. Have you seen the outrageous prices for them brand new?
Randy
Old Jan 8, 2002
AZ2K1Civic's Avatar
Ive done some research on this and I think you might need a capacitor (Doubt thats spelled right). It takes energy from you alternator and stores it so you that your amp can power your subwoofers. This way the alternator wont drain the battery. I think you should be able to go to any audio store and they'll know what your asking for.
Hope that helps.
Old Jan 8, 2002
mohawkboom's Avatar
Hey Read in the I.C.E section on how much my electrical system can take.. also.. from AmpmanAudio You can get an Ohio generator 180 amp alternator for $569 with a 2 year warranty..But I'd reccomend putting the stock pulleys back on as well.. AEM pulleys and others free up 2 hp not even worth the gain on our cars..also your alt spins slower and makes it harder to develop amperage.
Cheers
Mohawk
Old Jan 8, 2002
2k2civic's Avatar
That's why they are caleld underdrive pulleys - because they underdrive the alternator to stop it from robbing power that would otherwise be going to the wheels.
Old Jan 8, 2002
Zillaaa's Avatar
Zillaaa is an unknown quantity at this point
If you can wait...
Get the unorthodox racing pullies.
They are by far the besy pullies to get for your car.
Old Jan 8, 2002
bambuski's Avatar
bambuski is an unknown quantity at this point
I think AZ2K1Civic has it right, Before I got my capasitator(SP) whenever i came to a stop at night with my systems on, whenever the bass hit my lights would dim. I got a Cap and that solved it.
Old Jan 8, 2002
AlphaInfinity's Avatar
AlphaInfinity is an unknown quantity at this point
Rockford fosgate makes a .5 for 500 watt systems that you can get at car toys for 106, and RF also has a 1.0 for 1000 watt systems that you can get for around 160.
Old Jan 8, 2002
nymbus2k's Avatar
nymbus2k is an unknown quantity at this point
IMO (may not make sense 'cause i'm still a newbie with this ish) .. since you are having problems with your alternator putting out efficient juice to run the stuff in you ride .. maybe you should put your alternator pulley back on, leaving it stock .. and leave the aem power steering pulley on ........ ?.
EDIT: i have the aem pulleys and bought a voltmeter to monitor my electrical system (i'm running i.c.e. in my ride .. but nothing compared to your's) ..... at idle .. it may drop down to 12v .. when the original voltage at idle is at around 13.5-14v ... this may be bad ..... ?.
Old Jan 8, 2002
drbombay's Avatar
drbombay is an unknown quantity at this point
put the stock pully back on. you need it. a light weight pully kit is what would probably work better for you.
Old Jan 8, 2002
Sean2k1's Avatar
Sean2k1 is an unknown quantity at this point
Yeah man dont go for all these new alternators or capacitors... they probabaly wont solve your problem... get them checked over... or just put the stock ones on... cause that aint supposed to happen with new pullys....
Old Apr 3, 2002
GeNoZiDe's Avatar
GeNoZiDe is an unknown quantity at this point
damn i wan pulleys
but my system would probably cause the same prob
im gonna do a lil more research and throw in a capacitor first [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Apr 3, 2002
Mbow's Avatar
AEM says if you have a system pushing 300 watts or more you will probably run into problems with their pulleys. I am going to get some soon. I may wait and save up for the unorthodox. They may only give a few hp but it all adds up.
Bonobo
Oct 2, 2015 06:58 PM
Dave Brabant
Sep 27, 2015 09:43 PM
AffliictiioN
Sep 16, 2015 02:21 PM
stank
Sep 16, 2015 07:40 AM
