12 w7 or 10w7 or 12w6v2....results.....went with the 10 w7
Old Jan 28, 2003
rodney's Avatar
rodney is an unknown quantity at this point
which one should i get i dont know what to do?
Rodney = Lost
the 12 w7 box wouldnt fit into the trunk (jl audio box)
so we went with the 10....and it slams.
i used to have 3 10 w6 and it is no where near as loud or good.
Old Jan 28, 2003
izod's Avatar
izod is an unknown quantity at this point
12w7 in either a sealed (better response) or ported (louder) box, with a 1000/1 amp. Kinda spensive, but WELL worth it [IMG]i/expressions/face-icon-small-smile.gif[/IMG]. You'll need to fatmat while you're at it.
Old Jan 28, 2003
DizWikedCivic's Avatar
Quote
[hr]Originally posted by: izod
12w7 in either a sealed (better response) or ported (louder) box, with a 1000/1 amp. Kinda spensive, but WELL worth it [IMG]i/expressions/face-icon-small-smile.gif[/IMG]. You'll need to fatmat while you're at it.[hr]
yup that a good setup but that way to expensive, if have the money go for it
Old Jan 28, 2003
rodney's Avatar
well i am getting the jl 500/1 for $350
the subs with enclosures go like this (jl enclosures)
$400 for the 12w6v2
$600 for the 10w7
$700 for the 12w7
money is really the issue....i just cant make up my mind
Old Jan 29, 2003
rino's Avatar
rino is an unknown quantity at this point
well if you only have the JL 500/1 amp I wouldn't do the 12w7 cause there isn't enough power. I would probably go with the 10w7 but if you sacrificed a little and get the 10w6 that amp will actually push that better than the 10w7 and sound better. That amp isn't enough for bigger subs and the w7's require alot more. Plus the 10w6 will be a bit cheaper.
Old Jan 29, 2003
HaLcYoN's Avatar
HaLcYoN is an unknown quantity at this point
Quote
[hr]Originally posted by: rodney
well i am getting the jl 500/1 for $350[hr]
With that amp, I'd say get the 10W7. the 500watts will power the 10w7 at it's rated rms
Old Jan 29, 2003
WhiteRabbit's Avatar
Quote
which one should i get i dont know what to do? [hr]
get whichever one you want. the only difference is frequency range and volume. (assuming you took the time to install it properly)
frequency range between the 10 and 12w7 is not too big, only low bass junkies (rap music fans, basically) would really be better off with the 12 as opposed to teh 10.
as to performance, the w6v2 is more or less the w7 without the volume potential.
good luck!
Old Jan 29, 2003
rodney's Avatar
rino are you smokin' actually the 500/1 will push the 12 w7 just fine anyone who has ever used this amp knows that it will actually do a lot more than 500 watts i used to have 3 10 w6 and the amp was too powerful for them.....so i dont even want to think about putting 1 10w6 on that amp cuz i know it will blow....hell i have seen the 250/1 blow a 10 w6
Old Jan 29, 2003
amps dont blow speakers, improper tuning does.
a 500/1 is perfect for a 10w6 is perfect for a 10w7 is perfect for a 13w7 is perfect for a DD 9515 is perfect for a sony xplod. more power would be required to get louder, thats all. Or careful gainwork to ensure the woofer doesnt bottom, or top. And most people would rather turn it up past clipping for that apparent SPL, when they have too little power, when what they are really doing is causing massive damage to a woofer.
you could run a 13w7 off a 250/1 and it will sound just as beutiful as it would off a 1000/1. you can be darn sure it wouldnt get as loud [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
the 500/1 woul dbe an ideal amp for any of those subwoofers. cost and space are your two enemies, here.
Old Jan 29, 2003
Hwoody77's Avatar
Hwoody77 can only hope to improve
Hey I can get those W7's for a lot cheaper...I work at Sixth Ave Electronics...PM me if you want them for cheaper[IMG]i/expressions/face-icon-small-smile.gif[/IMG]. Plus I've done buisiness with a few members before...
Old Jan 29, 2003
Ed's Avatar
Ed
wow, you work at 6ave? [IMG]i/expressions/face-icon-small-smile.gif[/IMG] That's where i got my HU after a post here. it was a Pioneer 7400, but they were out so i got the premier instead [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Jan 30, 2003
LudlamTheory's Avatar
i boogie for the raindrops
Quote
rino are you smokin' actually the 500/1 will push the 12 w7 just fine anyone who has ever used this amp knows that it will actually do a lot more than 500 watts i used to have 3 10 w6 and the amp was too powerful for them.....so i dont even want to think about putting 1 10w6 on that amp cuz i know it will blow....hell i have seen the 250/1 blow a 10 w6[hr]
you're quite wrong my friend... JL's amps are ridiculously regulated, thats what their amps are known for, and thats why sound quality freaks buy them... Those amps put out a constant 500 watts under any circumstances, no more, no less... and whoever you know blew a 10w6 with a 250/1 is a damn moron...
Old Jan 30, 2003
ChemicalBoom's Avatar
ChemicalBoom is an unknown quantity at this point
Dont believe EVERYTHING you hear. but believe it or not Ludlam is right. a 12W7 would take a JL 1000.1 and smile.
And i assume you are talking about the old w6's, and they could take 450-500 each w/o blowing. Maybe if u pumped
500 watts and ran it for 2 days on a 30HZ test tone it would break down but they have great integrity. if u want my opinion
you can't go wrong with the 12W6 with that amp. plus you can spend the xtra cash on sound deadening. its worth it.
Old Jan 30, 2003
rodney's Avatar
ok since that is supposedly true then why could a sub that can hold 400-500 watts be blown with a 250 watt rated amp
Old Jan 31, 2003
lots of distortion really loud, really low. pop!
Old Jan 31, 2003
Quote
[hr]Originally posted by: WhiteRabbit
lots of distortion really loud, really low. pop![hr]
either that or a horrendous install
Old Feb 1, 2003
FaintReality's Avatar
FaintReality is an unknown quantity at this point
With 500w or less, the JL reps over at the carsound forums said the W6v2's will sound better than the W7's. A single 12W6v2 or 13W6v2 on a JL 500/1 would be nice. The 10" are pretty in-efficient, so I would stick with the 12" or 13". Plus they will get a little louder and play a little lower.
As for the commet about the JL 500/1 only pushing out 500w rms, no more, no less, you are wrong. The JL reps said they put out 20% more power than they are rated at, so the 500/1 will put out around 600w rms. The 500/1 carsound bench tested put out over 700w rms.
By the way, I am selling a brand new JL 300/2, and two JL 500/1 amps.
This is a re-post from the for sale forum...
I have a JL 300/2, and two JL 500/1's for sale. The JL 300/2 and one of the JL 500/1's are brand new. The other JL 500/1 had been in my car for the past 3 weeks, but ran very lightly since it is hooked up to a 12" MMATS sub, in which it only handles 250w rms. All amps are in mint condition, even the used amp. They were all purchased from an authorized JL dealer, and have all receipts. I am looking to get $275 for the 300/2, $300 for the used 500/1, and $350 for the new 500/1. Those are the going prices on ebay, so unless you come across a good deal, it won't be beaten, especially since mine were purchased from an authorized dealer.
I will accept money orders, or paypal from verified users only (address must be verified). I am a verified paypal user as well. Prices above do not include shipping. I will only charge you the actual shipping cost, in which shouldn't be over $15 if in the US since they don't weigh very much. If you live in Southern Cali, you can pick up in person, for the prices mentioned above.
Please post here or email me at faintreality@hotmail.com if interested or have any questions. For features and specs, please visit www.jlaudio.com
Thanks, Dave
JL 300/2 pics...
New JL 500/1 pics...
Used JL 500/1 pics...
Old Mar 29, 2003
aznslim7's Avatar
aznslim7 is an unknown quantity at this point
PPI & 12W7
Yo should go to JLaudio.com to check it out 500/1 for 10w7 or 12w7, even better 1000/1 for 12w7 or13w7. It will blow ur ear ... My setup is 12w7 with PPi PCX2200....
Old Mar 29, 2003
wow... pick an older thread to write in...
SleekOne
Jul 6, 2006 04:39 PM
jayjdlc
Jun 16, 2006 02:06 PM
simmons.213
May 20, 2005 05:07 PM
Sim012
Apr 19, 2004 08:13 PM
NitehawkVTEC
Aug 31, 2003 02:36 AM
