JL 10W7 and an Audison Lrx 1.400 or JL 500/1?
Old Jul 4, 2006
SleekOne's Avatar
SleekOne is an unknown quantity at this point
Which do you think will match the 10W7 better? No one around here has Audison but I get the impression that they're superior to the JL. Problem is that the Jl 500/1 puts out all of it's power no matter what load it's pushing (the W7 has a 3ohm voice coil) and I'm not sure that the Lrx does the same. I'm not sure that the Audison will be powerful enough to push the W7, but I'd prefer to use it because it's supposed to sound better.
Any advice? someone hear the audison?
Old Jul 4, 2006
white2K2EX's Avatar
I sure wish my car was newer
I've never heard the Audison, but I had a 10W7 and 500.1 in my last car and it worked perfectly. I'm pretty picky and I had no qualms.
Old Jul 4, 2006
sl0wEM2's Avatar
GO LOW or GO HOME
sl0wEM2 has a spectacular aura aboutsl0wEM2 has a spectacular aura about
Jl 500/1
Old Jul 4, 2006
FERIOHHHHHHHHHH's Avatar
FERIOHHHHHHHHHH will become famous soon enough
1000/1 =] its better to have more thgen enough power then not enough. but if had to be between the 2.. 500/1
Old Jul 5, 2006
WhiteRabbit's Avatar
http://www.audison.it/prodotti.asp?l...1&idprodotto=4
350 @4
650 @2
900 @1
meaning the w7 gets basically just as much power from each amp, even though the audison is rated for 900 rms capability versus the 500 from JL.
Personally? I would start to think about aesthetics and future upgrades. the audison might make swapping subwoofers in the fuure nice, have extra power on reserve, etc.
but if your stage amp is a JL 300/2 or two, it would make no aesthetic sense at all to run audison for the bottom end.
at this point, I wouldnt be basing my decision on accoustic reasons, I wouldnt be able to come up with any concrete motivation to go one way or the other!
but financially? aesthetically? I could come up with plenty to sway me in either direction!
if you require personal experience to make an opinion credible, I've heard both amplifiers and I run all audison in my own install.
Last edited by WhiteRabbit; Jul 5, 2006 at 02:24 AM. Reason: Automerged Doublepost
Old Jul 6, 2006
eye_see_you's Avatar
let the devil out
the 10w 7 can be easily over powered so the 500/1 is a best match IMO and I run one now
simmons.213
May 20, 2005 05:07 PM
Scola
Mar 26, 2005 07:32 PM
Sim012
Apr 19, 2004 08:13 PM
FaintReality
South Cali
Feb 19, 2003 07:51 PM
FaintReality
Feb 1, 2003 02:29 AM
