amp for 10W7
Old Aug 29, 2003
NitehawkVTEC's Avatar
NitehawkVTEC is an unknown quantity at this point
amp for 10W7
I'm gettting a 10W7 in a pro wedge box. Right now i have a phoenix gold XS2500. I'm looking at an MTX6500D to power it also. which would be better.
my friend at the audio store tells me that nothing will compare to the JL500/1 when powering this sub. is this true? will it really make a big differencE?
Old Aug 29, 2003
Mystic3030's Avatar
Yup, i'm an A$$hole.
Basically you need something that will put out 500-600 watts at 3 ohm. JL 500/1 would be great, those are the amps I have and I like them. The downside is they are more expensive than other brands. To find an amp that puts out 500 watts at 3 ohm you are probably going to need an amp that puts out around 1200 watts at 2 ohm. HiFonics Burtus 1500 might do the trick, or the JBL 1200.1
Old Aug 29, 2003
LudlamTheory's Avatar
i boogie for the raindrops
mystic, dont reccomend that crap to a 10w7....
10w7 would work beautifully with a 500/1
a phoenix gold tantrum 1200 would also work pretty good...
i could probably think of a few more amps
Old Aug 29, 2003
but neither the PG XS2500 or the MTX6500D are well suited for a 10W7 right? so basically i should just pick up a 500/1? or what else do you suggest?
Old Aug 29, 2003
Mystic3030's Avatar
I was just suggesting those as something for someone on a low budget.
It it were ME, I would run a Phoenix 800.1 or 600.2 Titanium, JL 500/1, PPI PCX2200, a Diamond D7152, or something really god awfully expensive from Zapco
Old Aug 30, 2003
lol. i'm not really after cheap that much. i'd just like to save money. my 4 channel amp is McIntosh, and I have a nakamichi deck....
Old Aug 30, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
get the JL Amp .. u need something to run 3ohm's or .75 cause i have 13.5 W7 and its being powered by a kicker zr600 and a hifonics boltar...
i got my amps before i had the sub .. but if i would have gotten the sub first i would have the JL 1500 amp for it.. cause it runs the right OHM.. which keeps the amp stable.. puts more power to the sub and doesnt over head the amp at all.
Old Aug 30, 2003
you have 2 different amps hooked up to your sub at once?
and JL doesnt make a 1500
Old Aug 30, 2003
slicksivik's Avatar
i got a jl 500/1 on my 10w7 and it sounds real good. i wish i had two instead of one, haha.
Old Aug 30, 2003
slicksivik's Avatar
i actually run it on half bass boost and like on -6 on my headunit and its still quite loud. i do that because all the money i spent on my system im scared to just blow it, haha. if i had two, i'd just feel more comfortable. haha.
Old Aug 30, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
yea ? i have two amps connected.... u sure they dont make a 1500? i guess is 1000 then..
Old Aug 31, 2003
hooking up 2 amps to one sub is a BIIIIIIIIG nono... im surprised you havent royally f*cked that sub up yet
Old Aug 31, 2003
especially 2 different amps! but remember. but even if they were the same model, no two amps are really the same.
h4ldol
Apr 24, 2017 08:16 PM
UltraHDGames
Jun 8, 2016 05:16 PM
wingsfan19
Oct 1, 2015 03:45 AM
Mc7602
Sep 17, 2015 02:01 PM
redcloud
Sep 7, 2015 01:45 PM
