Wiring from Front door to Headunit or to Trunk
Old Jan 20, 2003
zoooh's Avatar
zoooh is an unknown quantity at this point
How do I do this? I tried to search for it but couldn't find it. Can anyone help me?
Old Jan 20, 2003
slammed's Avatar
slammed is an unknown quantity at this point
A little more detail would be helpful.
Old Jan 20, 2003
zoooh's Avatar
Thanks for the reply.
I am trying to wire component speaker in front door to my amp in the trunk using my own wire. I know how to wire from HU to the trunk but I have no idea how to get the wire into the front doors. So I was thinking if someone can let me know how to run wire from the front door to the HU, I can run it to the trunk. Or the way to run wire from the front door directly to the trunk...
It would be really helpful if someone can give me bit of instruction on how to do this. Thanks.
Old Jan 20, 2003
Toca's Avatar
Toca is an unknown quantity at this point
Alright... I wish I had a digicam but i'll try and explain it....
First off get the door panel off (Follow The DIY)
Open the door.... You'll see a black rubber tube going from the door to the body off the car.
Pull the carpet back and take off the two fuse covers..
Find that hole and fish a coat hanger through theat rubber tube...
MAKE SURE YOU DON'T HAVE A SHARP EDGE
Attach the wire to the hanger and pull it through.
Follow the DIY for the HU removal. or if you're going to the trunk fish the wire under the carpet
Old Jan 21, 2003
zoooh's Avatar
Thank you so much.
I never worked with car stereo before... I just wanted to get as much information as possible before I get to work on it.
Now on a passenger side door, does panel underneath the glove box come off?
Old Jan 21, 2003
ChemicalBoom's Avatar
ChemicalBoom is an unknown quantity at this point
Yes just yank it, but just pull it out enough to work with. its a pain getting it back in
Old Jan 21, 2003
Toca's Avatar
I forget but i'm not sure if i took anything out on the passenger side... I dunno if it was needed.. But i gues just start yankin
Old Jan 21, 2003
OyD's Avatar
OyD
OyD is an unknown quantity at this point
Quote
[hr]Originally posted by: Toca
Follow the DIY for the HU removal. or if you're going to the trunk fish the wire under the carpet[hr]
everything he said except instead of a coat hanger use a 24" zip tie. its a lot more flexable and won't get caught all the time when you try to fish it through
Old Jan 21, 2003
jefff's Avatar
jefff is an unknown quantity at this point
Just get a wife with little fingers!
Youshoe
May 22, 2015 09:36 PM
MamaBear2015
May 18, 2015 07:37 PM
MamaBear2015
May 3, 2015 02:17 PM
djdefcon
17
Apr 6, 2005 11:52 PM
doublins
Nov 11, 2001 07:01 PM
