Subwoofer Grill.....
Old Jan 12, 2003
ZSKCivic01's Avatar
Extreme Member
ZSKCivic01 is an unknown quantity at this point
I was searching on crutchfield and I found this grill for subwoofers.
Click Here
I have a JL Audio 12w3 and I was looking at the screw configuration and it looks like the same one as the 12" JL audio subs. Will this one fit mine?
Old Jan 12, 2003
Subrage's Avatar
Subrage is an unknown quantity at this point
it should, but i cant guarentee anything
Old Jan 12, 2003
sadboy916's Avatar
HISPAnIC CAUSIn PAnIC
have u seen audiobahn grills they look the best
Old Jan 13, 2003
LudlamTheory's Avatar
i boogie for the raindrops
just make sure the grill isnt too close to the sub... you dont want it hitting
Old Jan 13, 2003
custom2k1's Avatar
custom2k1 is an unknown quantity at this point
Most subs have the eight hole config that the grill uses, but the thing you have to remember is that the momo grill sits in the counter sunk holes of the cage of the polk momo sub and the screws that thru the grill hold the sub in the enclosure as well. It may work but your probably going to have a gap in between the enclosure face and the bottom edge of the grill and it may not seal up so well.
Old Jan 13, 2003
andyman97's Avatar
Turbo Guru
I have a JL 12w3 as well and I just picked up a set of JL 12" grills. They have a mounting plate that lays between the sub and the box and the grill clamps between the sub and the mounting plate. I think it's a very nice, high quality grill and it was designed for JL sub excursion....it sounds just as good with the grill on as it did before. Check it out here.
Mad Dog Tannen
Oct 19, 2016 08:12 PM
wingsfan19
Oct 1, 2015 03:45 AM
wingsfan19
15
Sep 2, 2015 02:15 AM
WLakers
May 4, 2015 06:23 PM
LudlamTheory
Jul 28, 2002 03:45 AM
