passive crossovers in the door
Old Dec 29, 2002
dups's Avatar
dups is an unknown quantity at this point
Is it ok to just kinda put the passive crossover in the door behind the midrange? I installed my speakers a while ago and its rained and stuff but somebody told me that was a really bad idea because they will get wet. Anyways, I just want to make sure they will be safe inside the door for long term use. Thanks!
EDIT: The speakers I'm using are infinity reference 605cs if that makes a difference. Thanks
Old Dec 29, 2002
OyD's Avatar
OyD
OyD is an unknown quantity at this point
wouldn't that be bad for your speakers and all the other electrical stuff in your door?
Old Dec 29, 2002
mohawkboom's Avatar
generally passive crossovers are installed between the door panel and the outside of the door, not behind the speaker
Old Dec 29, 2002
dups's Avatar
so you're saying I should move it or do you think since its already where it is at that it will be fine where I have it?
Old Dec 29, 2002
mohawkboom's Avatar
if you have it behind the speaker..I'd definately so move it or it might short out and cause your speakers and amp to blow...
First Car
Sep 8, 2015 08:54 PM
Brad Andrew
Sep 8, 2015 08:22 PM
redcloud
Sep 7, 2015 01:45 PM
18
Aug 17, 2015 08:02 AM
ballmich
Jul 9, 2015 11:59 AM
