Dumb HU question
Old Dec 5, 2002
fonto's Avatar
The LA Clipper
Dumb HU question
If I put a new HU in my ride that's output voltage is twice as much this would mean that I would need to turn down the gain on my amps, right?
In turn would this mean that my amps would be sucking less power from my battery because my gains are turned down a bit lower??
Old Dec 5, 2002
Subrage's Avatar
Subrage is an unknown quantity at this point
turn them down a bit
Old Dec 5, 2002
mohawkboom's Avatar
not exactly..power consumptionis related to output..gains make no difference if the outputis the same..however having your gains down low will result in a cleaner more noise resistant signal. All systems have some degree of added noise. With your gains up high your amplifying the signal and the noise so it's more audible in your speakers. With the gains lower..you signal is being amplified less so less ambient noise is amplified so you get a cleaner more noise free sound
Old Dec 5, 2002
fonto's Avatar
The LA Clipper
Thanks for the replies! I am going to be upgrading from a Kenwoon KDC-319 to an Kenwood Excelon KDC-x549, atleast I think those are the numbers. So I will be going from 2 volts to 3 4.5 volt outputs. As you can tell, I like Kenwood CD players.
Old Dec 5, 2002
mohawkboom's Avatar
Kenwood 4.5 volts is really 2.2 volts..trust me I've tested some.. 4.5volts peak maybe
Old Dec 5, 2002
fonto's Avatar
The LA Clipper
Then I wonder what the 2 volt ones are [IMG]i/expressions/face-icon-small-tongue.gif[/IMG]
Anyway, if you would not I have told me I would have Never known [IMG]i/expressions/face-icon-small-sad.gif[/IMG][IMG]i/expressions/face-icon-small-tongue.gif[/IMG]
Old Dec 5, 2002
mohawkboom's Avatar
2,2 volts still is not a bad thing..depends on how loud you like your music.. turn your volume **** 4/5 of the way and set your gain for as loud as you listen to music and you'll be allright.. if you never crank it.. you can keep the gains down pretty low
Old Dec 5, 2002
Subrage's Avatar
my bad
Old Dec 5, 2002
mohawkboom's Avatar
Quote
[hr]Originally posted by: Subrage
my bad[hr]
What..you have 8 volt pre-outs..your gains should be at ZERO!!! [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Dec 5, 2002
LudlamTheory's Avatar
i boogie for the raindrops
or mr fonto, you can keep the same unit, get an audiocontrol crossover, and set your gains to 0, audiocontrols have built in line drivers...
Old Dec 5, 2002
Subrage's Avatar
Quote
[hr]Originally posted by: mohawkboom
Quote
my bad[hr]
What..you have 8 volt pre-outs..your gains should be at ZERO!!! [IMG]i/expressions/face-icon-small-smile.gif[/IMG][hr]
they are about 1/16th up maybe less
Old Dec 5, 2002
fonto's Avatar
The LA Clipper
Ludlam, My gf is getting it for me for x-mas...and I kinda like the idea of having a dedicated output for my subs [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
My current head unit is way down on the Kenwood scale, so I wanted to upgrade.
juror
Suspension DIY
Jul 30, 2019 03:28 AM
JMKendrick
Sep 16, 2015 06:17 PM
junkyardguy
Sep 2, 2015 06:07 PM
Supamann
Aug 31, 2015 02:14 PM
NoobyKid
Jul 13, 2015 07:53 AM
