Distribution Block
Old Dec 4, 2002
scrible's Avatar
scrible is an unknown quantity at this point
Distribution Block
If I'm running 3 amps, 1 (mono) amp, and 2 (2-ch) amps do I have to run 3 power wires, 1 of each guage from the battery and go their own seperate ways from there? Or can I run 1 power wire like 0 gauge to a distribution block and break from there into 1 4gauge and 2 8guage wires?
Old Dec 4, 2002
Litespeed's Avatar
Litespeed is an unknown quantity at this point
Run only one power lead from you batter to the inside of your car, then use a distrobution block to divide that power lead into more power leads to power your 3 amps.
Old Dec 4, 2002
scrible's Avatar
ok that sounds better, buying 3 fuse holders and 3 distribution blocks sounded wallet breaking [IMG]i/expressions/beer_yum.gif[/IMG]
Old Dec 4, 2002
scrible's Avatar
can u steer me into the right direction of distribution block made by stinger either HPM series or Expert series?
Old Dec 4, 2002
fonto's Avatar
The LA Clipper
Sound Domain has a good selection of Distribution blocks
Old Dec 4, 2002
Subrage's Avatar
Subrage is an unknown quantity at this point
thezeb.com will charge you less
Old Dec 4, 2002
fonto's Avatar
The LA Clipper
I am having a bad situation with theZeb right now, so until it is rectified and I get the correct item that I ordered from them I won't reccomend them to anyone.
Old Dec 5, 2002
LiKEaFeRiO's Avatar
The attached pic should help you out.
Put a fuse near your battery like you would for 1 amp then run the power wire to your distribution block in your trunk.
I think I remember reading that its not safe to have a live wire going from your engine bay all the way to your trunk.
[IMG]/forums/themes/orbitz/paperclip.gif[/IMG] Audio Setup.jpg (40 Kb)
Old Dec 5, 2002
alex053's Avatar
Lightning Audio makes a block that is 0guage in and has 3 four guage outputs. It is not fused but this is what i use. You can either get in platinum (GD3) or gold (BD3).
Old Dec 5, 2002
andyman97's Avatar
Turbo Guru
I'd get one with fuses as well. You can never be too careful. This way there is even less chance of damaging components.
Old Dec 6, 2002
OyD's Avatar
OyD
OyD is an unknown quantity at this point
here's a good read for you
linked
Old Dec 6, 2002
LudlamTheory's Avatar
i boogie for the raindrops
hey man, you really have no need for running all this super expensive high quality stinger cable.... if the install is done well, then it would sound identical with an inferior product... all psychoacoustics after the install
Old Dec 6, 2002
fonto's Avatar
The LA Clipper
Check out this link: Stinger Distribution Block
This is the block that I use, and if you go by the page that OyD posted you won't need a fused block because you will have 4 gauge being split into two 4 guage outputs.
styles234
21
Nov 19, 2019 07:23 AM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
emiixo
Exterior
Sep 22, 2015 03:53 AM
MichaelLW
Sep 14, 2015 07:15 AM
dantheman42
Sep 4, 2015 01:10 PM
