MASS vs. EVO-R vs. Eclipse
Old Dec 3, 2002
ChemicalBoom's Avatar
ChemicalBoom is an unknown quantity at this point
Ok, for their similar prices which sub will perform better?
with my JBL 1200.1
Old Dec 3, 2002
LudlamTheory's Avatar
i boogie for the raindrops
which eclipse.. theres 4... im assuming you refer to the titanium... beautiful speaker.. i'd go with the titaniummmmmm ... but for that price + slightly more you can drop in w7's... if you refer to alums, mass gets slightly louder and slightly lower (only 2 db's or so)... but i personally love the sound of the alum... evo-r ive never heard
Old Dec 4, 2002
yeah i was talking about the Alums. But where did you see a titanium for as cheap as
a mass? i've been thinking of the W7 but $500 is the cheapest i can find.
Titaniums are
thanks for the response.[IMG]i/expressions/beer_yum.gif[/IMG]
Old Dec 5, 2002
mohawkboom's Avatar
Well I've had EVO-R's and Eclipse alums in 12 and 15" and my g/f Had a Mass 2010 in her car before...so I can really help you out here..
If your that concerned about sound quality. Use a class A/B amp..it makes a world of difference with woofer control. The Eclipse will require the most power tog et any decent SPL out of it. the EVO-R is by far the most efficient. The MASS has the best frequency response and plays the lowest while maintainting great woofr control. The EVO-R is basically a more efficient Eclipse alum...they really really have the same output properties and responce in sealed enclosures..but the EVO-R's hit harder. The MASS, IDMAX and W7 are basically the 3 best subs for high output while retaining incredible fidelity. Using a Class D amplifier though and you'll never let the subs sound as good as they can because of the ultra slow slew rates of the amps (time gap between changing polarity) it causes some overhang,
Whatever your choice may be. Feed them with at least 500Wrms of class a/b Power!!
Old Dec 5, 2002
My JBL 1200.1 is class D right? I wanted to get a big amp so i would have the
possibility of wiring it for 1200 or 600 watts depending on the sub.
Not the cleanest amp in the world but im hoping my install and sub will pick up the slack [IMG]i/expressions/face-icon-small-tongue.gif[/IMG]
thanks u guys
Old Dec 5, 2002
look into getting an aftermarket Xover
Old Dec 5, 2002
mohawkboom's Avatar
Quote
[hr]Originally posted by: LudlamTheory
look into getting an aftermarket Xover[hr]
Yeah Class D amps are allright..but if your in it for sound quality they are not the way to go... judges can hear the difference a mile away..
With JBL amps..always try to use an outboard crossover..their built in X/O's pretty much just plain suck
Old Dec 6, 2002
which crossover would you suggest?
Old Dec 6, 2002
mohawkboom's Avatar
anything that Says Audiocontrol or Phoenix gold....
Old Dec 6, 2002
theyre not that expensive ebay style
the reason i like audiocontrols is because you can dial in the frequency to the dot... you go to radio shack and spend like $1.25 on a module and some resistors, and you have the crossover frequency... only XO i know of that you can say "i have my Xover set at exatly 84 Hz"
i just got one specifically to use with a jbl for 40 bucks on ebay... audiocontrol 2xs, but you can go with whatever you want...
Old Dec 6, 2002
fonto's Avatar
The LA Clipper
Are head unit LPFs usually bad to use?
Cam Diaz
Sep 29, 2015 07:17 PM
michael0219
Sep 1, 2015 10:25 PM
jordan1794
Jun 11, 2015 09:14 PM
Wild Cranker
May 19, 2015 06:10 PM
