do you like ? tv/head unit
Old Dec 25, 2002
  #61
LudlamTheory's Avatar
i boogie for the raindrops
hah... a dremel is what i got for xmas... i love this ****in thing
Old Dec 25, 2002
  #62
fonto's Avatar
The LA Clipper
Dremel is the best tool that I have ever bought!!! It is a great tool, especially when half of our cars are plastic!! [IMG]i/expressions/face-icon-small-tongue.gif[/IMG]
Old Dec 25, 2002
  #63
beamer's Avatar
beamer is an unknown quantity at this point
Quote
[hr]Originally posted by: AzNmiKex215
hey i just had another inovative idea. instead me cuttin all those lil holes to mount the faceplate i have thought of a better way!.
what i am gonna do is get a metal hinge like this
and then screw both sides into the headliner (less holes and less sloppy)
and then just attach the face to the metal hinge via double sided tape. i just only hope that it will attach it strong enough for it to not move. what do you think? is that 3M tape really strong? could anyone recommend anything stronger?
[hr]
you will still have holes. there is no way to get around that. Not that I know of.
Old Dec 25, 2002
  #64
beamer's Avatar
Quote
heres and update. i have the "headunit eject" problem figured out now i am in the proccess of running wires.
i also have the headunit mounted were i wanted. here are some pics
[hr]
you just gave me one hell of a good idea. I'll get some pic. nice work
Old Dec 25, 2002
  #65
AzNmiKex215's Avatar
2k1civic.com O. G.
now the problem with puttin the headunit there is that u have to extent the wiring harnesss for power. this wasnt too... hard. [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
now i am trying to figure out how to extent the cable for the antenna to reach down here.
*VERY IMPORTANT. if u plan on putting your headunit were mines is it will not just slide all back together, as i had hoped. there is a metal bracket in the way. it is on the LEFT side of E-BRAKE (*when sitting normally) and will not allow the headunit to slide all the way down. hence not leeting the plastic trim piece lock back into stock position. tommorow i will be cuttin away at some of the metal bracket just enought to make it fit.
another solution would be to raise the headunit up some. but taht would call for modifying the plastic trim. which i probably wont be able to do and make it "pretty". so i will just resort to cuttin away the metal bracket that no1 will ever see anyway.
thanx
Mike
Old Dec 28, 2002
  #66
beamer's Avatar
looking good
Old Dec 29, 2002
  #67
2k1civic.com O. G.
well im all done the radio. i should have some pics up tonight. i still have to wait for the antenna extension cable to come in. it should be here tommorow or tuesday along with my 5.6 LCD. (*arghH i gotta rip everything apart again )
now all i need is some Detailed info on how u mounted the LCD beamer... that is if u dont mind sharing [IMG]i/expressions/demon.gif[/IMG]
Old Dec 29, 2002
  #68
beamer's Avatar
I don't mind at all I just have to think of the best way show you. I'm going to try something different.
Old Dec 30, 2002
  #69
2k1civic.com O. G.
it is done theres more pics but im waitin for my cuz to send them to me.
now i just need to make some kinda peice to cover all the gaps.
Old Dec 30, 2002
  #70
2k1civic.com O. G.
does anyone know were i can get maybe some thin sheets of plastic or something similiar i can use to cut out a shape to cover the gaps around my screen?
anyone have any other suggestions on how to go about doing this?
Old Dec 30, 2002
  #71
mcmaster.com
Old Dec 31, 2002
  #72
WhosYoDadday85's Avatar
www.ImportFactor.Com
WhosYoDadday85 should not be trustedWhosYoDadday85 should not be trusted
What kind of brackets are those that you are using to secure the screen in there? Good job..a lot better then what I did when I put mine in my console...
As for the "plastic" that you are refering to, plexiglass all the way
Old Dec 31, 2002
  #73
2k1civic.com O. G.
those brackets came attached to the screen. they can be removed. what i did was cut two slits on the underside of the ac vents to slide the top of the brackets upward. and i just positioned the bottom right bracket so that the screw hole lined up with the hole that the Defrost controls screwed into. i screwed everything together and it holds pretty tightly.
a link to the screen is posted on page 6 of this thread i think. its pretty good for 100 bucks. i should buy 2 more for the headrest.
Old Jan 1, 2003
  #74
beamer's Avatar
partsexpress.com
Old Jan 3, 2003
  #75
WhiteRabbit's Avatar
you guys are my heros. finally some really really good custom work being done, and a very good job at that!
Old Jan 3, 2003
  #76
beamer's Avatar
thanks
Old Jan 4, 2003
  #77
2k1civic.com O. G.
wow we got praise from whiterabbit!!
thanx
and special thanx to beamer for all his help.
Old Jan 9, 2003
  #78
beamer's Avatar
no prob. How did you mount the hu by the e-brake? did you have to cut? I think i'm going to do the same. I like how yours looks.
Old Jan 9, 2003
  #79
i like how yours looks [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
with a detatched face, it would be rediculously easy.
mine barely fits, i used 1/4 inch high quality ply as my base, and sanded it smooth, then cut holes in it. fit the trim ring on, then backfilled it with putty. then glassed over the whole thing with carbon. done.
if you put yoru whole radio in there, youll have to watch out for the e-brake mount, i guess i noticed it and forgot about it later, some others here have tried it and didnt notice till the test fitting. doh!
if you route just teh face there, piece o cake, and itll go right up agaisnt teh back, if you want.
Old Jan 9, 2003
  #80
2k1civic.com O. G.
yeah the ebrake mount had to be cut away for the bottom of the headunit to fit. i burned some of my carpet in the process of cutting it [IMG]i/expressions/face-icon-small-frown.gif[/IMG]
my headunit is actually attached to the stock pocket thingy. since its basically the same width and lenght i took it apart. the pocket thingy becomes two halves. it just barely fits the headunit some cutting away at the plastic is required. and i just ghetto rigged and duct taped it to the half of the pocket that has the screw holes taht screw into the trimpeice u see (*painted blue in my pics). so once its securely taped onto the pocket thingy, the pocket thingy can then be screwed back into its stock place.
if u still dont cant picture how i did it. i would be happy to take it apart and take some nice pics for u.
*another con into doing this is that if u do not have 12 different color wire [like me] you would hav to run each wire individually untill u get all twelved connected on each end. i used all the same wire so i had no way in telling what wire goes to which pin on each end if i pulled all the wire through at once. this also disables me from ever disconnecting one of the ends to completely take the headunit out of my car. (unless of coarse i lable all 12 wires)
Old Jan 10, 2003
  #81
Quote
*another con into doing this is that if u do not have 12 different color wire [like me] you would hav to run each wire individually untill u get all twelved connected on each end. i used all the same wire so i had no way in telling what wire goes to which pin on each end if i pulled all the wire through at once. this also disables me from ever disconnecting one of the ends to completely take the headunit out of my car. (unless of coarse i lable all 12 wires)[hr]
labeling is easy... masking tape
Old Jan 10, 2003
  #82
HotRidezcom's Avatar
Dog
HotRidezcom has a little shameless behaviour in the past
what a sick job [IMG]i/expressions/laugh2.gif[/IMG]
Old Jan 10, 2003
  #83
Dog
i take it back, what a damn super sick job [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Jan 14, 2003
  #84
beamer's Avatar
10-4 roger dat[IMG]i/expressions/beer_yum.gif[/IMG][IMG]i/expressions/face-icon-small-puke.gif[/IMG]
Old Jan 17, 2003
  #85
theguysmiley's Avatar
theguysmiley is an unknown quantity at this point
I'd like to try the same thing with my headunit, but I don't know if I can. I have a Panasonic CQDFX972U:
I haven't taken a very close look at the back of the HU though, so I don't know if I'd be able to do it the same way that you guys have. I'll keep you posted.
If I can't seperate the faceplate from the HU, I atleast want to relocate the whole thing down in the 12v socket place (above the cup-holders).
Oh yea...NICE JOB!!!
Old Jan 17, 2003
  #86
Quote
[hr]Originally posted by: theguysmiley
Oh yea...NICE JOB!!! [hr]
is yours motorized?
Old Jan 17, 2003
  #87
No, it's not motorized...thank goodness (Motorized=more parts to break)
It's removable, and to put it back in place you have to put the bottom left corner in first, push it in a little bit, and then slip in the bottom right side. Since I'm not familiar with the back of the face-plate, I'm not sure if the electrical current travels through the hinges on the bottom or though a "contact-point" like most face-plates. I'll let you know when I find out.
Old Jan 17, 2003
  #88
2k1civic.com O. G.
it should be generally the same setup. the faceplate should have a few metal pins or connections that touch the headuints matching set of pins when the faceplate is in the closed position.
now if headunit makers would make the faceplate communicate with the headunit wirelessly via infared or some kinda bluetooth tech.. relocation would be so easy, and it would open up so many doors for creative mounting
Old Jan 18, 2003
  #89
beamer's Avatar
you should be able to do it. I don't see why it would be any different than a pioneer. they both have to connect some how. if you can take a pic of the back of the face so we can see. we'll help ya out.
Old Feb 4, 2003
  #90
nolimitrican's Avatar
nolimitrican is an unknown quantity at this point
damm man that project is tight man, thats some ill ish, looks playa im gonna see if i can do that but those it has to be a pioneer hu cause i have a jvc kd-sx780. well anyways good job man gotta give it to both of yall.. thx
