Box Building Help
Old Nov 24, 2002
Les's Avatar
Les
Les is an unknown quantity at this point
Box Building Help
ok i'm going to try and build my first box. I used winisd as best as i could to try and figure it out. It's a dd 3512 single sub in a 5 cuft ported to 40 hz. Here's my question. I'm going to slot port it. I was just wondering what the numbers in vent match mean? is it better to try and make the port as high and wide as i can fit in there? does that have an effect on how the sub will sound? thanks for the help
Old Nov 24, 2002
custom2k1's Avatar
custom2k1 is an unknown quantity at this point
I would download perfect box and use that. It will give you a box design and port sizing all in one program and then plot of the response of the sub. You can also call DD and ask a tech for his idea. Most techs are more then happy to talk on the phone for awhile discussing what will sound best for your car and your music style.
Old Nov 25, 2002
Ed's Avatar
Ed
I'm pretty sure that if you just make the slot the same surface area and depth, it'd be the same as a round one or something.
Old Nov 26, 2002
BlueTroll's Avatar
BlueTroll is an unknown quantity at this point
where can i find the program Perfect Box??
Old Nov 26, 2002
Ed's Avatar
Ed
A lot of us use this program, WinISD. It sounds just like Perfect Box.
http://www.linearteam.dk/winisd.html
Old Nov 26, 2002
Les's Avatar
Les
Yeah that's what I use, winisd. I was just wondering if there's any advantage of making the slot bigger. It'll still be tuned to 40hz, but say I go from a width of 4 in to 6 in. It increases the length of my port by 7 in. Is there any reason to do this?
Old Nov 26, 2002
alex053's Avatar
Vent mach has to do with the velocity of air moving out of the port. If its to high you will have a noisy whistling port. If you going 5 cubes (assuming thats build to) you should use 50 square inches of port, 12.5 inches deep. added port area will help increase efficiency to a point. anything over about 80% of you cone area is going to act kinda like a hole in the box.
GolNat
Nov 27, 2018 03:32 PM
Dave Brabant
20
Oct 6, 2015 12:44 AM
Jrosa
Sep 14, 2015 08:24 PM
Zedoc
Engine Swaps
Sep 12, 2015 04:27 PM
