Factory Ground
Old Nov 17, 2002
fonto's Avatar
The LA Clipper
Factory Ground
I want to update my factory ground to 4 gauge, is there anything special I should do or look out for when I do it? Should I make the ground point the same on that lil copper colored thing? Should I upgrade any other wiring also?
Old Nov 17, 2002
LudlamTheory's Avatar
i boogie for the raindrops
if youre gonna upgrade factory ground, then upgrade the 2 wires coming from the alternator as well
Old Nov 17, 2002
Subrage's Avatar
Subrage is an unknown quantity at this point
Upgrade the Big 3 is always a must (well not always)
Old Nov 18, 2002
fonto's Avatar
The LA Clipper
What are the big 3? And where are the factory grounds from the alternator? Is that the one that is right in the front center under the hood?
Old Nov 18, 2002
alternator isnt connected to the ground... theres chassis to - on battery,
Old Nov 18, 2002
Abstract's Avatar
Abstract is an unknown quantity at this point
the big 3 are
battery ground to chassis ground
engine ground to chassis ground
alternator positive to battery positive
Old Nov 18, 2002
fonto's Avatar
The LA Clipper
Thanks! I think I will just do the battery ground 'cause that is the only thing that I can figure out [IMG]i/expressions/face-icon-small-tongue.gif[/IMG]
Old Dec 17, 2002
fonto's Avatar
The LA Clipper
I did my my battery ground and I have a few questions to make sure that I did it right:
1. The negative ground goes from the negative battery terminal to the chasis of the car ( the wire is bare for a few inches and is connected by a bolt) then the wire keeps going to a brass thing that looks like it is hooked to either the alternator (or engine, with the last four inches bare). What I did was that I connected 8 gauge wire to were the chasis is then i took 4 gauge wire and I hooked it directly to the brass thing from the negative terminal, and I made the last 4 inches bare. Did I do this right, or should I hooked the negative of the battery with 4 gauge to the chasis, then from that spot on the chasis have a 4 gauge wire going to the brass part on the alternator (or engine?)?
2. Where is the engine ground? Is it that silver bare wire that is right in the front center under the hood (right in the middle when you look down at the engine)?
Thanks, i would really appreciate some help on this because I feel like I may have done something wrong.
Sorry if these are stupid questions
Old Dec 18, 2002
fonto's Avatar
The LA Clipper
anyone?
jdh022764
18
Nov 3, 2015 06:44 AM
Donahue
Sep 9, 2015 05:55 PM
Bricoleur
Sep 9, 2015 12:23 PM
Bman2212
Sep 2, 2015 11:49 AM
