Amp blowing fuses instantly
Old Dec 17, 2002
illusion's Avatar
illusion is an unknown quantity at this point
I've had the same amp powering a sub for over a year now. Turned on HU the other day and realized that the sub wasn't playing. Checked the amp and the fuse was blown. Replaced the fuse, turned on deck, POP! blown again.
I've checked for the obvious short, the sub tests ok at 2 ohms with the meter, and the amp blows even when it's not connected to the sub.
Any ideas before i hit ebay for a new amp?
Old Dec 17, 2002
VNlilMAN's Avatar
The Standard One
check your ground.. maybe its loose or something
Old Dec 17, 2002
Mystic3030's Avatar
Yup, i'm an A$$hole.
Sounds like a blown capacitor in the amp....if it is, say bye bye amp....cheaper to just buy a new one than get that fixed. Is your amp a 2 channel? If you bridged at 2 OHM's, chances are you blew out the caps inside that way....unless the amp is designed to do so, you should only bridge at 4 OHM's and above. A friend of mine did that with his kenwood amp...same exact problem.
Old Dec 17, 2002
mohawkboom's Avatar
Could be a blown cap in the amp or a fried transistor rail...it might be repairable for pretty cheap...
Old Dec 18, 2002
illusion's Avatar
Yeah that's exactly what i was doing... bridged 2ohm load.
Oh well new/better amp on the way now... [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
redcloud
25
Aug 12, 2015 01:23 PM
15EXCoupe
Jul 30, 2015 12:59 PM
Civic65
Jul 19, 2015 10:13 AM
mistermenphis22
Jul 13, 2015 04:43 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
