Is 1/2inch MDF ok for a small single-sub enclosure?
Old Nov 12, 2002
slikor's Avatar
slikor is an unknown quantity at this point
i just got 2 Alpine Type-E 10" subs, and a Profile 600MSX mono amp, and im working on building my custom trunk enclosure. my plan is to put each sub in one front corner of the trunk, right behind where the taillights are. i removed the carpeting in the trunk, and there looks to be plenty of space to build a decent size enclosure there. here is my problem: i need to use 1/2inch MDF for the enclosures, because there is not enough room for the box if i use 3/4inch. everything i've read on building sub boxes says use 3/4inch MDF at least, but i want to know if its ok if i use 1/2inch. i mean, the box is small and built in a way that it seems it will be very strong, and doesnt have any large panels so i wouldnt imagine the thinner walls would resonate too bad, as compared to 3/4inch. how should i proceed?
thanks.
Old Nov 12, 2002
mohawkboom's Avatar
Not really.. 5/8 is the thinnest I'd go and make sure to brace the corners...
Old Nov 12, 2002
JDog2001CivicEX's Avatar
JDog2001CivicEX is an unknown quantity at this point
The smallest I ever went was 3/4" for MDF. and that held 2 Cerwin Vega's. I actually ended up shattering the box in a USAC dB drag competition. My little '85 Honda CRX HF was never the same again, I never got the smell of MDF out of the car
Joe
Old Nov 12, 2002
slikor's Avatar
yeah but this isnt your regular square box, i mean it has many small panels because it is made to fit in the corner of the trunk which is an odd shape. it seems to me because of all the joints and everything it'd be strong enough using 1/2inch...what would be the worst that could happen if it was not strong enough?
argh, friggin 3/4inch will make it so hard to fit...damn
Old Nov 12, 2002
WhiteRabbit's Avatar
fiberglass. [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Nov 12, 2002
andyman97's Avatar
Turbo Guru
IMO nothing, I don't think you will blow the box apart or crack it. Even if you do, which I seriously doubt that you would, all you would have to do is build a new box. 1/2 inch should be fine. True, 3/4, or 5/8 is recommended, but not necesarry, I mean they are only 10's. I had a box built from 1/2 inch for two kicker comp vr 12's and it sounded awesome and I didn't brace anything or do anything special, just the box with a divider. You can go with 3/4, but you don't HAVE to.
Old Nov 12, 2002
Litespeed's Avatar
Litespeed is an unknown quantity at this point
I wouldn't go any smaller than 3/4"
Old Nov 13, 2002
JohnDoe's Avatar
JohnDoe is an unknown quantity at this point
.5" will flex more which will make it sound sloppy/boomy. Also you say you have a buncha little panels... a buncha flaxing panels and it won't stay sealed. More panels means more joints which means more likelyhood of it not staying sealed. Stick with the 3/4"
Old Nov 13, 2002
BlackSI's Avatar
BlackSI is an unknown quantity at this point
thats too thin
Old Feb 7, 2003
noahnoah's Avatar
noahnoah is an unknown quantity at this point
3/4 or 5/8 is recommended by most individuals. 1/2 really is too thin, and I don't think that 3/4 is that much more expensive, go with what you know is best, that way you don't have to worry about what the worst that could happen......I could understand your dilemma if 3/4 was 4 times the price or something and you needed 80 feet of it.......
get 3/4
Old Feb 7, 2003
LudlamTheory's Avatar
i boogie for the raindrops
youd think that if he posted this 4 months ago he might have done something about it by now....
Old Feb 7, 2003
Ed's Avatar
Ed
Quote
[hr]Originally posted by: WhiteRabbit
fiberglass. [IMG]i/expressions/face-icon-small-smile.gif[/IMG][hr]
I'd do fiberglass..
wow, this is old!!
ricer_em2
May 11, 2016 08:09 PM
Sep 27, 2015 11:33 AM
General DIY
Sep 25, 2015 08:02 PM
bhollie
Sep 22, 2015 11:08 PM
pilebuck13
Sep 21, 2015 10:45 PM
