installation
Old Nov 10, 2002
rd2k2cvc's Avatar
rd2k2cvc is an unknown quantity at this point
installation
I'm installing an amp and 2 10" subs to go along with my MP3 player. As far as installation goes, what all will I need and how much will it cost to install my amp, subs, and mp3 player. Anything u guys could tell me would help a lot. thanks
Old Nov 10, 2002
civicvtec1ps's Avatar
Search and Learn
for installing cd player you will need wireharness and installation braket.which you can purchase at bestbuy for 15.99 each.
and about amp and subs. you can get amp wiring kit or amp kit less than 100 bucks for sure. i bought mine at walmart(cause im cheap) costed me 30 bucks i believe
Old Nov 10, 2002
Litespeed's Avatar
Litespeed is an unknown quantity at this point
The wiring harness and mounting brackets are cheap... $15 - $20.
For the amp it depends on how much power it puts out. For amps that put out more power you'll need a larger power lead which will cost more. For a 4 gauge kit it shouldn't cost you more than $60 - $70. 4 gauge is usually good up to about 700 watts. Make sure you get the wiring kit that comes with the RCA cables (if you don't already have them).
You'll also need some speaker wire to run from the amp to your subs. It should only cost a few bucks for several feet of say about 12 gauge speaker wire.
Old Nov 11, 2002
2k2civic's Avatar
If you need a wiring kit, I would highly recommend KnuKonceptz.com. They have 4 gauge wiring kit (includes, RCAs, power and ground wires, speaker wires, fuse and connectors) for about $30. Also, try looking for subs and amp on ebay, but buy your enclosure locally or build it yourself.
mjdiaz89
Jun 21, 2016 09:26 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
mrwhos
Aug 11, 2015 02:03 AM
17
Jul 23, 2015 11:48 PM
EM_WON
Jul 22, 2015 06:49 PM
